Warning message
Spanning-tree Question on Port-channels
Oct 22nd, 2010
Can you apply spanning-tree portfast to a Port-channel or should the spanning-tree statement just go on the interfaces asscoiated with the Port-channel?
Dan-Ciprian Cicioiu Fri, 10/22/2010 - 06:38
  • Gold, 750 points or more
If you enable portfast on the port-channel , the ports on the portchannel will be also portfast (the portfast will apear onyl in the cfg of the portchannel.)
You can verify that with : show spanning-tree interface detail | i portfast
Dan
