Warning message
QuickVPN doesn't connect to RVS4000
Oct 22nd, 2010
I've installed QuickVPN on Windows XP, configured an account on the router.
But when I'm trying to connect to the router I get the following:
MS NT5 ISAKMPOAKLEY 00000004]
Oct 2 06:25:33 - [VPN Log]: packet from 1.1.1.1:500: ignoring Vendor ID payload [FRAGMENTATION]
Oct 2 06:25:33 - [VPN Log]: packet from 1.1.1.1:500: received Vendor ID payload [draft-ietf-ipsec-nat-t-ike-02_n] method set to=106
Oct 2 06:25:33 - [VPN Log]: packet from 1.1.1.1:500: ignoring Vendor ID payload [Vid-Initial-Contact]
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: responding to Main Mode from unknown peer 1.1.1.1
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Oakley Transform [OAKLEY_3DES_CBC (192), OAKLEY_SHA1, OAKLEY_GROUP_MODP1024] refused due to strict flag
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: transition from state STATE_MAIN_R0 to state STATE_MAIN_R1
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: STATE_MAIN_R1: sent MR1, expecting MI2
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: NAT-Traversal: Result using draft-ietf-ipsec-nat-t-ike-02/03: no NAT detected
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: transition from state STATE_MAIN_R1 to state STATE_MAIN_R2
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: STATE_MAIN_R2: sent MR2, expecting MI3
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Main mode peer ID is ID_IPV4_ADDR: '1.1.1.1'
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: I did not send a certificate because I do not have one.
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: transition from state STATE_MAIN_R2 to state STATE_MAIN_R3
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: STATE_MAIN_R3: sent MR3, ISAKMP SA established {auth=OAKLEY_PRESHARED_KEY cipher=oakley_3des_cbc_192 prf=oakley_md5 group=modp1024}
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: cannot respond to IPsec SA request because no connection is known for 192.168.160.0/24===2.2.2.2[S?C]...1.1.1.1[S?C]
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: sending encrypted notification INVALID_ID_INFORMATION to 1.1.1.1:500
Oct 2 06:25:34 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x9995a83b (perhaps this is a duplicated packet)
Oct 2 06:25:34 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: sending encrypted notification INVALID_MESSAGE_ID to 1.1.1.1:500
Oct 2 06:25:36 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x9995a83b (perhaps this is a duplicated packet)
Oct 2 06:25:36 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: sending encrypted notification INVALID_MESSAGE_ID to 1.1.1.1:500
Can anybody help with this?
Thanks in advance.
davbarre Fri, 10/22/2010 - 11:21
Hi Aleck,
Can you please post your Quick VPN log as well?  It's default location is C:\Program Files\Cisco Small Business\Quick VPN Client
Located in this directory is a log.txt file.
Thanks!
Dave
AleckNesterov Sat, 10/23/2010 - 05:54
Unfortunatelly OpenVPN doesn't save logs
Here is a list of files:
23.10.2010  15:50              .
23.10.2010  15:50              ..
16.11.2009  13:31           155 705 CFP.exe
16.11.2009  13:31             2 958 Cisco.ICO
09.12.2009  13:26            14 848 DetectEnvStatus.exe
02.10.2010  11:46              Image
02.10.2010  17:38               132 ipsec.conf
12.04.2010  14:11            61 440 IPSEC.exe
16.11.2009  13:31           154 112 IPSec.msc
16.11.2009  13:31            71 680 ipseccmd.exe
16.11.2009  13:31            19 968 IPSECUTIL.DLL
02.10.2010  17:38                 0 isakmp_status.conf
16.11.2009  13:31         1 097 728 libeay32.dll
23.10.2010  15:50                 0 list.txt
16.11.2009  13:31            16 121 News
02.10.2010  23:59                 1 Op.txt
16.11.2009  13:31           315 392 openssl.exe
16.11.2009  13:31           106 496 PingDLL.dll
16.11.2009  13:31            49 210 ProcNICs.dll
02.10.2010  11:48              profiles
16.11.2009  13:31               246 Readme.txt
02.10.2010  17:08               798 RVS4000_Client.pem
02.10.2010  11:47               105 rw.INI
12.01.2010  15:46           217 088 rw_client.dll
16.11.2009  13:31           118 784 rw_regedit.exe
16.11.2009  13:31             4 022 sample.wgetrc
16.11.2009  13:31           200 704 ssleay32.dll
03.10.2010  00:00                79 status.conf
02.10.2010  17:39                56 stopconn.conf
16.11.2009  13:31            22 191 strings.txt
16.11.2009  13:31            20 480 TEXT2POL.DLL
16.11.2009  13:31             1 078 uninstall.ico
13.05.2010  11:04           581 632 VPNClient.exe
16.11.2009  13:31               673 VPNClient.exe.manifest
16.11.2009  13:31            71 146 VPNClientHlp.chm
03.10.2010  00:00                 0 vpnserver.conf
16.11.2009  13:31           221 184 wget.exe
16.11.2009  13:31           148 259 wget.hlp
16.11.2009  13:31           186 238 wget.html
03.10.2010  00:00               299 wget_error.txt
02.10.2010  17:38               365 wget_request_error.txt
02.10.2010  17:39               547 wget_stop_error.txt
