ISR G2 (1941) and IP SLA command
Answered Question
Oct 25th, 2010
Hi People;
I'm have a new cisco router, and i trying configurate the router with a 2 internet conections, using the ip sla and track commands to backup static route, but i dont could make this config, because the ip sla command not working.
In older configurations, i'm have this command:
ip sla 1
icmp-echo 200.200.1.1 source-interface FastEthernet1
timeout 1000
threshold 40
frequency 3
ip sla schedule 1 life for
ever start-time now
track 123 rtr 1 reachability
delay down 15 up 10
ip route 0.0.0.0 0.0.0.0 200.200.200.200 track 123
ip route 0.0.0.0 0.0.0.0 100.100.100.100 11
but in this router, the help of ip sla command display it:
xxx-xxx(config)# ip sla ?
  key-chain  Use MD5 Authentication for IP SLAs Control Messages
  responder  Enable IP SLAs Responder
xxx-xxx(config)#ip sla responder ?
  auto-register  Setup auto-register to hub
  tcp-connect    Setup tcp-connect responder
  udp-echo       Setup udp-echo responder
  <cr>
someone know how i make this config???
Correct Answer by Jon Marshall about 6 years 5 months ago
Not if you want to monitor the entire path on each link. I was wondering if performance routing could do it but i haven't really used that.
Jon
Did a bit of digging around and there is something definitely not right. Found this doc -
http://www.cisco.com/en/US/customer/docs/ios/ipsla/configuration/guide/sla_roadmap.html
The IOS links at the top of the doc, you can click on any of them and they take to you to the relevant section within the doc except for 15.1T for which there is no section.
Not sure what has happened to IP SLA. Perhaps someone else can help.
If they can't and you can open TAC cases then there is a new feature for the Network Infrastructure Forums where you can open a case from within a discussion. See this link for more details -
https://supportforums.cisco.com/docs/DOC-13613
Jon
Overall Rating: 5 (3 ratings)
Jon Marshall Mon, 10/25/2010 - 07:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
What feature set are you running on the router ?
Jon
gilbertojardim Mon, 10/25/2010 - 08:13
IP Base.
I need a special feature set to make this configuration? In the feature navigator this feature is available in IP Base....
Jon Marshall Mon, 10/25/2010 - 09:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Which IOS version are you running ?
I have just checked Feature Navigator with a 1941 running 15.0(1)M and it is not supported in IP Base. It is supported in DATA.
Jon
gilbertojardim Mon, 10/25/2010 - 09:21
The IOS version is 15.1(2)T....
I'm search by "Reliable Static Routing Back-up using Object Tracking"....
If i dont have this feature in IP Base, there other method to configure failover of static routes?
Jon Marshall Mon, 10/25/2010 - 09:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hmmm, there is something a bit funny here. If i search on 15.0(1)M then Feature Navigator list IP SLA operations. If i search under 15.1T there is no mention of IP SLA for any feature set ie. Base or DATA. Not sure what is going on unless Feature Navigator has not been updated properly.
Jon
gilbertojardim Mon, 10/25/2010 - 10:36
And without this feature, there other way to configure the failover between two internet connections and static routes? Without the ip sla feature?
Correct Answer
Jon Marshall Mon, 10/25/2010 - 10:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
Correct Answer
Jon Marshall Mon, 10/25/2010 - 10:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
johnelliot6 Thu, 02/03/2011 - 16:50
Just wondering if anyone had a solution for this - I've run into exactly the same problem on an 1841(w/ 3G) running IPBASE 15.1(3)T
Thanks.
aspensystems Thu, 02/10/2011 - 21:57
We are facing same problem with 1905 with 15.0(1)M2 for ip sla. Somebody said we need to open a TAC case with cisco.
ashok
gilbertojardim Fri, 02/11/2011 - 04:47
The IP Base software does not support ip sla feature.
You need the Security or Data License to use this feature.
Gilberto
dhaneesh ek Tue, 07/26/2011 - 07:14
sir,
whether
cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M6, REL
EASE SOFTWARE (fc1)
will support ip sla?
gilbertojardim Tue, 07/26/2011 - 11:38
What is your license level? you need the Security license ou data license to use this feature.
dhaneesh ek Tue, 07/26/2011 - 22:42
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M5, REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 23-Feb-11 14:19 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
TIWWW uptime is 48 minutes
System image file is "usbflash0:c1900-universalk9-mz.SPA.150-1.M5.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco CISCO1905/K9 (revision 1.0) with 225280K/36864K bytes of memory.
Processor board ID FGL152022DA
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1905/K9          FGL152022DA
Technology Package License Information for Module:'c1900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security       None           None          None
data            None           None          None
If it does no support , how i can make it work with IP SLA? whether i can upgrade ios?
Kindly advice...
Dhaneesh EK
aspensystems Thu, 07/28/2011 - 00:12
You need to procure SL-19-DATA-K9 for the 1900 series and configure. I have done the same and all IP SLA command would be viable.
regards
ashok
dhaneesh ek Thu, 07/28/2011 - 03:52
Thanks Ashok.
Whether it will support 1905 router?
Dhaneesh EK
ABIODUN OWOLABI Wed, 07/04/2012 - 18:06
Hi Gilberto,
Please clarify something, I have a customer having the IP Base license on 2911 and has the same issue. so they can buy the security license only, and IP SLA will work without the data license ?
Sudhir Gupta Tue, 01/29/2013 - 22:05
hi Abiodun and jon.marshall
we are facing issue on 1941 router cant able to run ip sla command
Router#show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 17:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Router uptime is 20 hours, 2 minutes
System restarted at 09:19:49 UTC Sun Jan 27 2013
System image file is "flash0:c1900-universalk9-mz.SPA.151-4.M4.bin"
[email protected].
Cisco CISCO1941/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FGL1640112Z
1 terminal line
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1941/K9          FGL1640112Z
data          None          None           datak9
my command “snmp-server view rttmon ciscoRttMonMIB included” fails.
Router(config)#snmp-server view rttmon ciscoRttMonMIB included
%Bad OID
is 1941 support these command or not, if yes wat are the steps and things to do..
ABIODUN OWOLABI Wed, 01/30/2013 - 00:26
Hi Gupta,
You need to upgrade from IPBase License to a minimum of data license or something higher (Security or UC license) to be able to run IP SLA command on any ISR G2 Router. Check the following URL for more clarification:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html#wp9000807
You can also optionally activate any of the Technology Licenses by following the steps below;
Router>enable
Router#configure terminal
Router(config)#license boot module c1900 technology-package securityk9
Router(config)#exit
Router#reload
please note that you may be prompted to accept End User Agreement in the activation process, that's fine.
That will give you 60 days of evaluation and you can run any of the commands supported while you purchase the license you need. The URL above will guide you on the license to upgrade to.
Sudhir Gupta Wed, 01/30/2013 - 01:13
dear Emmanuel,
i had activated evaluation for data license, so u  want to me activate security as well to  run those commands.
please suggest
same steps i had taken to activate data license.
ABIODUN OWOLABI Wed, 01/30/2013 - 11:02
With Eval Data License, you should be able to run IP SLA. But you can also turn on Eval Sec License and see what happens.
I tried your snmp command above (snmp-server view rttmon ciscoRttMonMIB included) on a router with Sec & UC and it worked ok.
