Design of wireless solutions with WLC 5508
There is a recommendation by Cisco of the minimum number of gigabit ports, which is to be installed by the amount of AP associated with a controller 5508, for 150 AP is associated with a driver, you must install at least 3 gigabit ports?
Please, we need this information to design a solution.
Best regards.
Giovanni Anfossi
Tiago Antunes Wed, 10/27/2010 - 01:41
  • Cisco Employee,
From the config guide Cisco 5500 series controllers have no  restrictions on the number of access points per port, but Cisco  recommends using LAG or multiple AP-manager interfaces on each Gigabit  Ethernet port to automatically balance the load:
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60mint.html#wp1277659.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Trending Topics - Security & Network
