Warning message
ZBF with GRE Tunnel (GRE over IPSec)
Oct 27th, 2010
I have a GRE tunnel between two ISR's. The tunnel works perfectly... until I apply a Zone based firewall using CCP Ver 2.3. Below is the firewall being applied to Router 1. As soon as it is applied I can no longer use the tunnel from Router 2. What steps might I want to take inorder to figure this out?
Router 1
WAN - XXX.XXX.XXX.196/26
Vlan25 - 10.1.25.0/24
Vlan50 - 10.1.50.0/24
GRE Tunnel - 10.254.254.196
Router 2
WAN - XXX.XXX.XXX.141/29
Lan - 10.0.25.0/24
GRE Tunnel - 10.254.254.141
Split GRE Tunnel for the 10.X.25.0/24 networks
ip access-list extended SDM_ESP
remark CCP_ACL Category=1
permit esp any any
exit
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
exit
ip access-list extended SDM_IP
remark CCP_ACL Category=0
permit ip any any
exit
ip access-list extended SDM_GRE
permit gre any any
exit
ip access-list extended SDM_AH
permit ahp any any
exit
ip access-list extended SDM_SSH
permit tcp any any eq 22
exit
access-list 104 remark CCP_ACL Category=128
access-list 104 permit ip host XXX.XXX.XXX.141 any
access-list 103 remark CCP_ACL Category=128
access-list 103 permit ip XXX.XXX.XXX.143 0.0.0.7 any
access-list 102 remark CCP_ACL Category=128
access-list 102 permit ip host 255.255.255.255 any
access-list 102 permit ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip XXX.XXX.XXX.192 0.0.0.63 any
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
exit
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
exit
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
exit
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
exit
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
exit
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
exit
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
exit
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
exit
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
exit
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
exit
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
exit
class-map type inspect match-all ccp-invalid-src
match access-group 102
exit
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
exit
class-map type inspect match-all SDM_VPN_PT
match access-group 104
match class-map SDM_VPN_TRAFFIC
exit
class-map type inspect match-all ccp-protocol-http
match protocol http
exit
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 103
exit
class-map type inspect match-any ccp-sip-inspect
match protocol sip
exit
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
exit
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
exit
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
exit
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
exit
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
exit
class-map type inspect match-any ccp-h323-inspect
match protocol h323
exit
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
exit
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  no drop
  inspect
  exit
class class-default
  no drop
  pass
  exit
exit
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  no drop
  pass
  exit
class class-default
  drop log
  exit
exit
policy-map type inspect sdm-permit-gre
class type inspect SDM_GRE
  no drop
  pass
  exit
class class-default
  drop log
  exit
exit
class type inspect SDM_VPN_PT
  no drop
  pass
  exit
class type inspect sdm-access
  no drop
  inspect
  exit
class class-default
exit
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
  exit
class type inspect ccp-protocol-http
  no drop
  inspect
  exit
class type inspect ccp-insp-traffic
  no drop
  inspect
  exit
class type inspect ccp-sip-inspect
  no drop
  inspect
  exit
class type inspect ccp-h323-inspect
  no drop
  inspect
  exit
class type inspect ccp-h323annexe-inspect
  no drop
  inspect
  exit
class type inspect ccp-h225ras-inspect
  no drop
  inspect
  exit
class type inspect ccp-h323nxg-inspect
  no drop
  inspect
  exit
class type inspect ccp-skinny-inspect
  no drop
  inspect
  exit
exit
zone security gre-zone
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
exit
zone-pair security sdm-zp-in-gre1 source in-zone destination gre-zone
service-policy type inspect ccp-inspect
exit
zone-pair security ccp-zp-out-gre source out-zone destination gre-zone
service-policy type inspect sdm-permit-gre
exit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
exit
zone-pair security sdm-zp-gre-in1 source gre-zone destination in-zone
service-policy type inspect sdm-permit-ip
exit
zone-pair security ccp-zp-gre-out source gre-zone destination out-zone
exit
zone-pair security ccp-zp-out-self source out-zone destination self
exit
interface Vlan50
description Vlan$FW_INSIDE$
zone-member security in-zone
exit
interface GigabitEthernet0/0
description WAN$FW_OUTSIDE$
zone-member security out-zone
exit
interface Tunnel0
zone-member security gre-zone
exit
interface Vlan25
exit
Atul Singh Tue, 11/02/2010 - 02:51
  • Cisco Employee,
I think the out to self zone is dropping gre packets which is why the tunnel is no coming up. Try putting this config after applying the firewall from ccp:
ip access-list extended SDM_GRE_1
permit gre any any
exit
class-map type inspect SDM_GRE_1
match access-group name SDM_GRE_1
exit
class type inspect SDM_GRE_1
  pass
  exit
exit
See how it goes..
