CiscoWorks LMS problem
Oct 27th, 2010
We are running CISCOWORKS LMS in our Data Network,
But right now getting below problem,
1.    Unable to integrate Cisco-3925 integrated service router
2.    Unable to integrate Cisco-2811 integrated service router
3.    LMS cannot sense link status
4.    LMS cannot auto discover link
Attached Image for your kind reference.Appreciate your concern about this issue.
HAFIZ AHMED Wed, 10/27/2010 - 22:12
LMS Version is 2.6 and we are unable to add 39 or 28 series router in LMS
Gaganjeet Chug Thu, 10/28/2010 - 04:19
  • Silver, 250 points or more
Hi Hafiz,
Kindly let me know how you are adding device to CiscoWorks LMS 2.6.
As a best practise, when you will add new device to CiscoWorks, you should not select the device type while adding the device to CiscoWorks. Let the ciscoworks collect the inventorty on device and identify it automatically.
To start with make sure you have the lastet MDF device packages install for Common Services and then install all device pachages for other components like RME, CiscoView etc but make sure to have lastest MDF install first.
Gaganjeet
