Warning message
Polycom and Tandberg videosession disconnected after 2 hours
Oct 28th, 2010
Gteetings!
Polycom and Tandberg video session disconnected after 2 hours and after reconnection it works fine during next 2 hours. please help me to fix this problem
I read a lot of posts about timeouts but it doesnt help.
I have ASA 5510 sec. plus license, Cisco Adaptive Security Appliance Software Version 8.2(3)
Polycom and Tadbberg via VLAN going through asa to the internet, because they located in different rooms and has a non-routable in internet IP.
here is some configuration:
Polycom and tandberg has IP from this subnet:
VSX7000_LOCAL_IP - local ip of polycom
TANDBERG_LOCAL_IP - local ip of tandberg
interface Ethernet0/2.993
vlan 993
nameif pubsvc
security-level 20
ip address 172.16.6.193 255.255.255.224
timeout's config:
timeout xlate 3:00:00
timeout conn 5:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 6:00:00 h225 6:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:00:00 absolute uauth 0:10:00 inactivity
timeout tcp-proxy-reassembly 0:01:00
traffic forwarding:
static (pubsvc,isp2) VSX7000_EXTERNAL_IP VSX7000_LOCAL_IP netmask 255.255.255.255
static (pubsvc,isp2) TANDBERG_EXTERNAL_IP TANDBERG_LOCAL_IP netmask 255.255.255.255
nat config:
nat (pubsvc) 5 VSX7000_LOCAL_IP 255.255.255.255
nat (pubsvc) 4 172.16.6.192 255.255.255.224
global (isp2) 4 TANDBERG_EXTERNAL_IP
global (isp2) 5 VSX7000_EXTERNAL_IP
h323 inspection in global policy:
policy-map global_policy
class inspection_default
//skip //
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
// skip
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect sip
ACL on isp2 interface. Object group ESH_VCS contain IP addresses of hosts that can call us:
access-list acl_in_isp2 extended permit ip object-group ESH_VCS host VSX7000_EXTERNAL_IP
access-list acl_in_isp2 extended permit ip object-group ESH_VCS host TANDBERG_EXTERNAL_IP
On tandberg and polycom i setup session time to 999 minutes. please help me to fix this problem
Tomonori Taniguchi Sun, 11/14/2010 - 21:45
  • Cisco Employee,
Are you refer to “Maximum Time in Call” parameter on Polycom VSX7000?
If not, what is “Maximum Time in Call” parameter under Call Settings on it?
icenterhq Sun, 11/21/2010 - 23:20
i dont remember parameter name exactly, but it setum maximum session time
This problem is solved now. It was PIX settings on other side and problem was solved useing well known timeout settings.
