Warning message
UC520 Liverecord IOS Supported
Answered Question
Oct 28th, 2010
I'm trying to enable liverecord and I get the error "current version of IOS not supported" I have upgraded the IOS and get the same error. I am trying to configure this feature through the CCA tool. What version of IOS for the UC520 do I require to enable liverecord?
I have attached the sh ver command.
I'm also having trouble opening the Auto Attendant through the CCA, it loads so far and then freezes???? Any Ideas?
Correct Answer by dksingh about 6 years 9 months ago
great...please mark this thread as answered
and rate when u get a chance.
Though I agree that CCA can be very painful and CLI works much better,
CCA does support configuring live record/monitoring.
There were some compatibilty issue between CCA and CUE versions that
were addressed in  CCA ver 2.2.5.
What CUE s/w do u have?
If u are comfortable with IOS/CUE CLI, I'd stick to it.
p.bevilacqua wrote:
Do not use CCA or other GUI tool, these are buggy and never produce good resutls.
I have one UC520 with YB6 and Liverecord, no problems.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Fri, 10/29/2010 - 05:44
  • Hall of Fame,
    Founding Member
Correct Answer
dksingh Fri, 10/29/2010 - 07:34
  • Cisco Employee,
lyle.stevens Fri, 10/29/2010 - 08:04
Thank you gents, I'll stick to the CLI for some of the programming. I am going to upgrade the UC520 to a new software pack and the CCA tool and try again just to see. Thanks again.
lyle.stevens Mon, 11/01/2010 - 06:25
I upgraded the CCA tool to 2.2(5) and the UC520 software pack to 8.0 and this solved the problems of programming through the CCA.
Correct Answer
dksingh Mon, 11/01/2010 - 06:58
  • Cisco Employee,
