Cisco QuickVPN client hanging at "Verifying Network" connecting to RV120W
Oct 29th, 2010
I have a brand new RV120W with version 1.0.0.12. When I connect (QuickVPN client 1.4.0.5) to it from my XP sp3 box (with firewall off) the client hangs at "Verifying Network" and eventually I get a dialogue box that says that the remote gateway is not responding. Do I want to wait?. In the QuickVPN status window it shows my account as online. I know that my ISP is not blocking 500/udp because I have built a LAN to LAN tunnel from the RV120W  to a ASA5510 in another state. I saw the suggestion that the WAN interface MTU be reduced to 1466 so I did that. No luck.
From the firewall log:
2010-10-29 16:36:24: INFO:  Adding IPSec configuration with identifier "username"
2010-10-29 16:36:24: INFO:  Adding IKE configuration with identifier "username"
2010-10-29 16:38:21: WARNING:  no phase2 found for "username"
2010-10-29 16:38:21: INFO:  IPSec configuration with identifier "username" deleted sucessfully
2010-10-29 16:38:21: WARNING:  no phase1 found for "username"
2010-10-29 16:38:21: INFO:  IKE configuration with identifier "username" deleted sucessfully
2010-10-29 16:38:21: ERROR:  sainfo identifier not found ("username")
2010-10-29 16:38:21: ERROR:  Failed to Delete the IPSec configuration with identifier "username"
2010-10-29 16:38:21: ERROR:  remote identifier not found ("")
2010-10-29 16:38:21: ERROR:  Failed to Delete the IKE configuration with identifier ""
Any ideas? Or does someone know a number I can call for tech support?
Mike
Herbert Baerten Sun, 11/21/2010 - 13:26
  • Cisco Employee,
since this question is about a product in the Cisco Small Business / Linksys range, please move it to the Small Business - Security community, where you will have a better chance of getting expert advice.
I hope this helps.
Best regards,
Herbert
