CUPS 7.0.8 Offsite Access to Presence Status
Oct 25th, 2010
I thought I had everything working perfectly today on my CUPS 7.0.8 server with CUPC 7.1.1.13850, but it seems I'm still missing one piece... I'm unable to set/retrieve Presence status when I'm not onsite. To clarify:
What works:
Desktop Phone Control
Softphone Control
All Green (Including Presence) on Server Health Status
What doesn't work:
User appears offline
Can't set status
Can't use IM
Can't see others' status
I searched through the forums and saw where it was recommended to go to CUPS > System > Security > Incoming ACL and then create a new entry for All, All so I tried this, but it has had no effect. Is there something I'm missing with that, or is there something else I should be looking at altogether?
I can post a log if it will help.
UPDATE: For a bit of clarification, for my "offsite" connection I am connected to the site by VPN tunnel, so DNS resolution is not an issue, and I do otherwise have access to that VLAN, but kudos if someone can identify any necessary ports I need to open for true outside access for my users for CUPC.
muranskycotech Tue, 10/26/2010 - 15:44
Here is a log file in case it helps with troubleshooting.
I made a successful call to myself via softphone, a failed IM with the word "test", a forced attempt to set status as Available, and a few minutes of idle while it waited for retried connections. I'm also posting a screenshot of the Server Health Status.
muranskycotech Wed, 10/27/2010 - 17:27
Still looking for some assistance on this one... I'm sure it's probably something simple I'm missing, but it's driving me crazy.
muranskycotech Sun, 10/31/2010 - 12:13
Am still looking for some help on this if anyone has any experience with this issue.
Thank you in advance!
muranskycotech Mon, 01/31/2011 - 15:06
Found the answer... turns out that I had to disable SIP filtering on my ASA.
Related Content
