Force VPN connection thru certian network connection
Nov 1st, 2010
We have the Cisco VPN client setup up on multiple laptops that need to connect back for a green screen session.  These are laptops in cars that have a cellular modem in their car that they are hooked in to the Ethernet port of their laptops.  When the mobile users make a wireless connection they will sometimes connect thru their wireless card instead of thru the Ethernet port that has the cell connection.  Is there any way to make it use a certain network card?
manish arora Mon, 11/01/2010 - 13:37
  • Silver, 250 points or more
Create a Persistenent Static Route on the laptop to route packets for VPN SERVER from the specified interface rather using the default gateway.
Manish
monroemis Mon, 11/01/2010 - 14:02
Man, didn't think about it that way..... Makes total since!!!!! Thanks!
manish arora Mon, 11/01/2010 - 14:08
Mark it answered if it helped you out ...
Manish
Related Content
