SSL VPN, "Login failed" and "WebVPN: error creating WebVPN session!"
Nov 3rd, 2010
Just ran the wizard for Anyconnect SSL VPN, created a tunnel group, a vpn pool and added user to it. When trying to logon on the SSL service, it simply says "login failed". I suspect that the user might not be in correct groups or so?
some relevant config
webvpn
enable wan
svc image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
svc enable
group-policy vpnpolicy1 internal
group-policy vpnpolicy1 attributes
vpn-tunnel-protocol svc
tunnel-group admins type remote-access
tunnel-group admins general-attributes
address-pool sslpool2
default-group-policy vpnpolicy1
username myuser password 1234567890 encrypted privilege 15
username myuser  attributes
vpn-group-policy vpnpolicy1
Debug:
asa01# debug webvpn 255
INFO: debug webvpn  enabled at level 255.
asa01# webvpn_allocate_auth_struct: net_handle = CD5734D0
webvpn_portal.c:ewaFormSubmit_webvpn_login[3203]
webvpn_portal.c:webvpn_login_validate_net_handle[2234]
webvpn_portal.c:webvpn_login_allocate_auth_struct[2254]
webvpn_portal.c:webvpn_login_assign_app_next[2272]
webvpn_portal.c:webvpn_login_cookie_check[2289]
webvpn_portal.c:webvpn_login_set_tg_buffer_from_form[2325]
webvpn_portal.c:webvpn_login_transcend_cert_auth_cookie[2359]
webvpn_login_transcend_cert_auth_cookie: tg_cookie = NULL, tg_name =
webvpn_portal.c:webvpn_login_set_tg_cookie_form[2421]
webvpn_portal.c:webvpn_login_set_tg_cookie_querry_string[2473]
webvpn_portal.c:webvpn_login_resolve_tunnel_group[2546]
webvpn_login_resolve_tunnel_group: tgCookie = NULL
webvpn_login_resolve_tunnel_group: tunnel group name from default
webvpn_login_resolve_tunnel_group: TG_BUFFER = DefaultWEBVPNGroup
webvpn_portal.c:webvpn_login_negotiate_client_cert[2636]
webvpn_portal.c:webvpn_login_check_cert_status[2733]
webvpn_portal.c:webvpn_login_cert_only[2774]
webvpn_portal.c:webvpn_login_primary_username[2796]
webvpn_portal.c:webvpn_login_primary_password[2878]
webvpn_portal.c:webvpn_login_secondary_username[2910]
webvpn_portal.c:webvpn_login_secondary_password[2988]
webvpn_portal.c:webvpn_login_extra_password[3021]
webvpn_portal.c:webvpn_login_set_cookie_flag[3040]
webvpn_portal.c:webvpn_login_set_auth_group_type[3063]
webvpn_login_set_auth_group_type: WEBVPN_AUTH_GROUP_TYPE = 4
webvpn_portal.c:webvpn_login_aaa_not_resuming[3137]
webvpn_portal.c:http_webvpn_kill_cookie[790]
webvpn_auth.c:http_webvpn_pre_authentication[2321]
WebVPN: calling AAA with ewsContext (-867034168) and nh (-849922864)!
webvpn_add_auth_handle: auth_handle = 17
WebVPN: started user authentication...
webvpn_auth.c:webvpn_aaa_callback[5138]
WebVPN: AAA status = (ACCEPT)
webvpn_portal.c:webvpn_login_aaa_resuming[3093]
webvpn_auth.c:http_webvpn_post_authentication[1485]
WebVPN: user: (myuser) authenticated.
webvpn_auth.c:http_webvpn_auth_accept[2938]
webvpn_session.c:http_webvpn_create_session[184]
webvpn_remove_auth_handle: auth_handle = 17
webvpn_free_auth_struct: net_handle = CD5734D0
Rudresh V Wed, 11/03/2010 - 03:42
  • Cisco Employee,
Hi ,
Please make sure HTTP service is enabled on the ASA with the command "http server enable". But you said you used the wizard to configure Anyconnect, so i think this is already present.
Also please provide the output of "sh run http" from the ASA. Also please run the debug "debug http" and let us know the output.
Cheers,
Rudresh V
3moloz123 Wed, 11/03/2010 - 04:32
AnyConnect says:
"The secure gateway has rejected the agents VPN connect or reconnect request. A new connection requires re-authentication and must be started manually. Please contact your network administrator if this problem persists.
The following message was received from the secure gateway: Host or network is 0"
Other resources indicate that it's either the tunnel group, or the address pool.. The address pool is:
ip local pool sslpool2 172.16.20.0-172.16.20.254 mask 255.255.255.0
asa01# debug http 255
debug http enabled at level 255.
asa01# webvpn_allocate_auth_struct: net_handle = CE9C3208
WebVPN: calling AAA with ewsContext (-845538720) and nh (-828624376)!
webvpn_add_auth_handle: auth_handle = 22
HTTP: net_handle->standalone_client [0]
webvpn_session.c:http_webvpn_find_session[159]
WebVPN session created!
webvpn_remove_auth_handle: auth_handle = 22
webvpn_portal.c:ewaFormServe_webvpn_cookie[1805]
webvpn_free_auth_struct: net_handle = CE9C3208
ewsStringSearch: no buffer
Close 0
webvpn_auth.c:webvpn_auth[581]
webvpn_session.c:webvpn_update_idle_time[1463]
WebVPN: session has been authenticated.
Close 0
Close 0
webvpn_allocate_auth_struct: net_handle = CE863DE8
webvpn_free_auth_struct: net_handle = CE863DE8
Close 0
webvpn_allocate_auth_struct: net_handle = CE9C32C8
webvpn_free_auth_struct: net_handle = CE9C32C8
Close 0
Close 0
Close 0
Close 0
HTTP: Periodic admin session check  (idle-timeout = 1200, session-timeout = 0)
Close 0
Close 0
webvpn_allocate_auth_struct: net_handle = CC894AA8
Close 1043041832
webvpn_free_auth_struct: net_handle = CC894AA8
b.gamble Tue, 01/14/2014 - 06:40
I encountered this error message when I exceeded the number of licensed WebVPN connections. We were using the 2 "free" licenses. When the 3rd simultaneous connection was attempted, RADIUS would grant the connection, but a debug on the ASA showed this error:
WebVPN: user: (jdoe) authenticated.
webvpn_auth.c:http_webvpn_auth_accept[3121]
This is different than your debug though, so it might not apply. On the user side in the webvpn interface they got a "login failed" error.
