CUBE Licensing in 29XX/39XX Routers
Answered Question
Nov 4th, 2010
Is Unified Border Element licensing enforced on the 2900 and 3900 ISRs?  If so, what command can I use to determine how many sessions my VGs are licensed for?  A show version just says I have the UC license.
Thanks!
Jeff
Correct Answer by dksingh about 6 years 3 months ago
CUBE licensing ("allow connections...." CLI) is not yet enforced (all honor-based at this time) although it  will become so in future. For demo purposes an
eval license is required, and for production environments a CUBE  license (FL-CUBE-XX) has to be ordered. All paper based and nothing to installl as such.
If u configure GK as well, u'd need to purchase and install GK license though.
Correct Answer by Jonathan Schulenberg about 6 years 3 months ago
CUBE is a RTU license and does not use a key. All you need to have is the UC license installed on the router to configure it.
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html
Right to Use Feature Licenses
The following licenses do not Cisco software activation and you can begin using the features upon receipt of the Right to Use Notification
Feature License Name
Prerequisites
License Types
CME
IP Base & UC
Feature (Counted)
SRST
IP Base & UC
Feature (Counted)
VXML Gateway
IP Base & UC
Feature (Counted)
CUBE
IP Base & UC
Feature (Counted)
Land Mobile Radio
IP Base & UC
Feature
Overall Rating: 5 (5 ratings)
Correct Answer
Jonathan Schulenberg Fri, 11/05/2010 - 04:01
Prerequisites
License Types
CME
IP Base & UC
Feature (Counted)
SRST
IP Base & UC
Feature (Counted)
VXML Gateway
IP Base & UC
Feature (Counted)
CUBE
IP Base & UC
Feature (Counted)
Land Mobile Radio
IP Base & UC
Feature
Aman Soi Fri, 06/21/2013 - 00:30
Hi ,
Is there any command to run on CUBE to find out how many sessions are active even though paper licence are applied  or any violation is happening ?
regds,
aman
Ayodeji Okanlawon Fri, 06/21/2013 - 01:21
You can use "show voip rtp connections" to see the number of active calls.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Aman Soi Fri, 06/21/2013 - 02:31
Hi AOK,
Can we see some sort of violation license as well?
regds,
aman
mohamedbineesh Thu, 07/18/2013 - 11:16
I already have a 3945 Router that have purchased long back
Now we are planning for a SIP TRUNK to Service provider ( PSTN).
We have UC License.
As we have not purchased CUBE license earlier with router , I would like to know
if its available to Purchase CUBE License and Session License
as spare ? if its Right to Use license..how to purchase and inegrate it with existing 3945 Router ?
gabiulici Mon, 02/16/2015 - 23:55
Hey,
Can you share with me please the config of the CUBE ( dial-peer, sip configuration with PSTN etc).
Thanks a lot for help
Ayodeji Okanlawon Tue, 02/17/2015 - 01:47
Gabiulici
Here is a detailed guide for you.
1. Configure CUBE for media flow through. In this Mode CUBE acts as a true B2BUA. Advantages you get include address hiding and security becaue CUBE terminates and re-originate both signalling and Media. In this mode CUBE becomes a point of demarcation from th external world.
2. Configure CUCM to use Delayed Offer and CUBE to convert delayed offer to ealry offer...This prevents the need for you to use MTP to send Early offer on CUCM
voice service voip
early-offer forced
3. Configure DTMF signalling method on sip trunk to "No preference" This setting allows Unified CM to make an optimal decision for DTMF and to minimize MTP allocation.
4. Configure your CUBE to meet the requirements of your ITSP. Ask if they have configuration templates or any specific configuration they like you to use. This will save you time troubleshooting. Most of them dont use the default port 5060 because of security, confirm with your proivider what ports they use.
voice service voip
allow-connections sip to sip
sip
early-offer forced
header-passing
error-passthru
5. Use SIP to SIP...Use end to end sip. CUCM---sip---CUBE--sip----ITSP
6. Create a Trusted list of IP addresses on your CUBE is your CUBE IOS is 15.1 .2(T) and above.
voice service voip
ip address trusted list
  ipv4 203.0.113.100 255.255.255.255
  ipv4 192.0.2.0 255.255.255.0
This is imprtant because sometimes your ITSP will send you a single ip address for signalling and will then send media on a different IP adress. So get all the IP address your ITSP is using and add them to the trust list as shown above
7. Configure your inbound and outbound dial-peer approriately
Inbound Dial-Peer for calls from CUCM to CUBE (CUCM sending 9 +all digits dialled to CUBE)
dial-peer voice 100 voip
description *** Inbound LAN side dial-peer ***
incoming called-number 9T
session protocol sipv2
codec g711ulaw
dtmf-relay rtp-nte
Outbound Dial-Peer for calls from CUBE to CUCM (SP will be sending 10 digits inbound)
dial-peer voice 200 voip
description *** Outbound LAN side dial-peer ***
destination-pattern [2-9].........
session target ipv4:<CUCM_Address>
codec g711ulaw
dtmf-relay rtp-nte
Note: If more than 1 CUCM cluster exists, you will have to create multiple such LAN dial-peers with “preference CLI” for CUCM redundancy/load balancing
Inbound Dial-Peer for calls from SP to CUBE
description *** Inbound WAN side dial-peer ***------------------(catch-all for all inbound PSTN calls)
incoming called-number [2-9].........
codec g711ulaw
dtmf-relay rtp-nte
Outbound Dial-Peer for calls from CUBE to SP
description *** Outbound WAN side dial-peer ***
translation-profile outgoing Digitstrip
destination-pattern 9[2-9].........
voice-class sip bind control source gig0/1
voice-class sip bind media source gig0/1
session target ipv4:<SIP_Trunk_IP_Address>:XXXX (where XXXX is the port number your provider is using if different from 5060)
codec g711ulaw
dtmf-relay rtp-nte
8. SIP Normalization:
You may need to configure sip normnalization to modify sip headers, CLI etc. A good example is during call forwarding. You may need to change your diversion headers to  match the CLI your provider is expecting.. if your call forwarding is failing during testing this may be the reason..We can help you with this.
9. Media Resources
Plan your solution properly. Consider if you will need Xcoders, MTP, Conference bridge etc. You may avoid the need for xcoders if you confure your regions properly and use voice class codecs on your sip profiles. It is important to know if there are any endpoints in your network that do not support dtmf relay rtp-nte. You can avoid the use of MTP if you configure your dial-peers to have multiple dtmf types for thos phones that do not support rtp-nte
e.g
dial-peer voice 1 voip
dtmf-relay rtp-nte digit-drop sip-kpml (if your phones support kpml..then this will be used)
If in your environment you will need to do xcoding or CFB then ensure you have PVDMS
.10.FAX
If you have FAX in your network, determine what fax protocol your sip provider supports. Dont assume. Ask them and confirm in writing  what they support. I have seen legal cases because of fax failures over sip trunks
Configure your FAX devices in seperate device pools and use porefix to route calls using G711 only. Even if you are using T38, ensure your fax use G711 to establish the voice calls
Finally
11. Have a detailed and carefully planned TEST Plan. Test the FF:
  • Inbound and outbound Local, Long distance, International calls for G711 & G729 codecs (if supported by provider)
  • Outbound calls to information and emergency services
  • Caller ID and Calling Name Presentation
  • Supplementary services like Call Hold, Resume, Call Forward & Transfer
  • DTMF Tests
  • Fax calls – T.38, modem pass-through--whichever one you decide to use
Correct Answer
dksingh Fri, 11/05/2010 - 04:43
Ayodeji Okanlawon Thu, 06/20/2013 - 12:53
Luis,
Yes it is still the same. CUBE licrenses are right to use, however you need UC license on the 2900/3900 gateways
jsmckinlay Tue, 04/12/2016 - 02:30
Hi, this post on the licence being honor based was very useful.
Do you know if this is still the case nowadays? Also, I understand that the whole platform can be licensed so it will work up to the maximum allowable on that platform. How can you tell if your router (in my case a 2921) has such a licences already? I would hate to have to pay twice!
Related Content
