System was restarted by bus error at PC 0x623A3CF8, address 0x23 at 10:43:44 UK Thu Nov 4 2010
Answered Question
Nov 5th, 2010
our router start restarting itself I believe its bug but I get the error below but did not find anything online for the fix
some people say you need to upgrade IOS
could you please help?
PRODUCT TYPE (Model Number): Cisco 2801
* SOFTWARE VERSION:IOS Version:12.4(4)XC7
* BRIEF PROBLEM DESCRIPTION:
2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(4)XC7, RELEASE SOFTWARE (fc1)
Compiled Wed 01-Aug-07 00:56 by alnguyen
Image text-base: 0x6008C860, data-base: 0x63185140
Stack trace from system failure:
FP: 0x661A7C30, RA: 0x623A3CF8
FP: 0x661A7C70, RA: 0x623A415C
FP: 0x661A7C98, RA: 0x623A2BC8
FP: 0x661A7CB0, RA: 0x62375880
FP: 0x661A7D10, RA: 0x6237F4BC
FP: 0x661A7D28, RA: 0x61840694
FP: 0x661A7D80, RA: 0x61841ACC
FP: 0x661A7DA0, RA: 0x61841B88
Correct Answer by Bert Gevers about 6 years 9 months ago
Hello Ozhan,
this reload is caused by the following defect:
CSCsd70772 Externally found moderate (Sev3) bug: Resolved (R)
NBAR: bus error when translating UDP packet
Integrated in  12.4(06)T04 12.4(09)T01 12.4(09.02)T
You can view the details of this defect in our bug tool:
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Upgrading to any version later than the ones above will fix the issue.
Bert
Overall Rating: 5 (1 ratings)
Peter Paluch Fri, 11/05/2010 - 03:19
  • Cisco Employee,
Hello Ozhan,
A bus error generally means that the CPU tried to access a memory location that is not physically accessible. In most cases, this is a problem of the operating system. You are running the 12.4(4)XC7 version which is quite old and in furthermore, it is a special branch of IOS that was created only to implement and test a particular enhancement feature, and this feature was then reintegrated back into the 12.4 or 12.4T train at some time later.
I therefore strongly recommend to upgrade to the newest 12.4 or 12.4T IOS in a particular feature set that fits your memory and FLASH resources, and see whether the problem is resolved.
Best regards,
Peter
imediacast2010 Fri, 11/05/2010 - 03:25
Hi Peter
Thanks for quick reply
Do you have any instruction that I can follow to upgrade the IOS ?
regards
Peter Paluch Fri, 11/05/2010 - 03:30
  • Cisco Employee,
Hi Ozhan,
See the next thread you have created - I have answered this question there.
Best regards,
Peter
Correct Answer
Bert Gevers Fri, 11/05/2010 - 03:45
  • Cisco Employee,
Hello Ozhan,
Bert
Related Content
