Warning message
Incoming call recording CME/CUE
Answered Question
Nov 5th, 2010
Is it possible to record incoming calls by pressing a certain button on the IPPhone to start recording, without using any third party software?
We are using CME 4.1 and CUE 3.1
Thanks in advance.
Grant
Correct Answer by paolo bevilacqua about 6 years 8 months ago
You are not supposed to send messages to CUE via IMAP. Only to retrieve them.
I have also tested notification (SMTP), that works fine also.
Correct Answer by Rob Huffman about 6 years 9 months ago
Hi Grant,
This is one of the restrictions with Live Record. The is from the doc
I linked in the first post;
"Live-recorded messages do not trigger a message notification when delivered to the voice mailbox"
Cheers!
Rob
Overall Rating: 5 (4 ratings)
Grant Bagdasarian Fri, 11/05/2010 - 19:29
Configured it. Works like a charm, now I just have to configure it in our call flow.
Thanks again!
Rob Huffman Sat, 11/06/2010 - 07:51
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Grant,
Nice work my friend
Glad to be of some small help here.
Cheers!
Rob
Grant Bagdasarian Sat, 11/13/2010 - 16:31
The live recording works fine, but I have 1 small problem, which I can't figure out why it's happening. When I create a conference with the CUE the call is being recorded and put in the mailbox. But I also configured the extension which has the mailbox to forward all incoming voicemail messages to an email address, but this does not happen.
When I leave a normal voicemail message to that same extension(without conference call with CUE) the voicemail message is being forwarded to my email address.
Is it possible to have recorded calls to be forwarded to an email address?
Grant
Correct Answer
Rob Huffman Sat, 11/13/2010 - 17:38
  • Hall of Fame,
    Founding Member
Hi Grant,
Cheers!
Rob
Grant Bagdasarian Sat, 11/13/2010 - 18:30
Ahhh, okay. Thank you.
So the only way to get those messages to an external device is by using third party software? Or does Cisco have some more tricks up it's sleeve?
Rob Huffman Sun, 11/14/2010 - 06:38
  • Hall of Fame,
    Founding Member
Hi Grant,
Have you tried Forwarding these "Live Record" messages? When they are Forwarded
they may become like a new message that does trigger an email notification
Cheers!
Rob
Grant Bagdasarian Sat, 11/27/2010 - 18:06
Sorry for my late reply, but what do you mean by forwarding the messages? How/Where do I configure this?
I also thought of something, but I dont know if it's possible. We have a NME-CUE module. Is there a way to retrieve certain voicemail messages manually from the harddrive of this device, through ftp or any other protocol?
Grant
paolo bevilacqua Sat, 11/27/2010 - 18:29
  • Hall of Fame,
    Founding Member
Yes, you can retrieve them using IMAP, or you can configure "notification" so they are via SMTP to the recipient as soon they are recevied.
Grant Bagdasarian Sat, 11/27/2010 - 19:31
Thank you. I already tried the 'notification' method, but that doesn't work, since it's not possible. Or is that something different from what I've tried?
I enabled/configured the IMAP Service on CUE, but when I add/configure a new account in Outlook 2007 (Using IMAP) the 'test account settings' button gives back the following response:
Log onto incoming mail server(IMAP) Completed
Send test e-mail message Failed
     Send test e-mail message:   The server responded: 553 5.4.4 Unab (Gets cut of here)
What kind of e-mail addres does the CUE expect? And where do I configure this?
Correct Answer
paolo bevilacqua Sat, 11/27/2010 - 19:35
  • Hall of Fame,
    Founding Member
Grant Bagdasarian Sat, 11/27/2010 - 19:47
Hmm. How did you get that to work? Rob pointed out "Live-recorded messages do not trigger a message notification when delivered to the voice mailbox". So I don't understand how you managed to get that to work.
paolo bevilacqua Sat, 11/27/2010 - 19:50
  • Hall of Fame,
    Founding Member
I missed that point, that may be very well be the case.
I was referring to email notification for regualar messages.
Grant Bagdasarian Sat, 11/27/2010 - 20:09
Aha, okay.
I configured the IMAP according to the following document:
Cisco Unity Express Voice-Mail and
Auto-Attendant CLI Administrator Guide
for 3.0 and Later Versions
Configured it, restarted the IMAP server. Added an user to a group. Gave the group the vm-imap privilege.
But when I click on send/receive in Outlook, nothing is shows in the inbox of the IMAP account.
paolo bevilacqua Sat, 11/27/2010 - 20:11
  • Hall of Fame,
    Founding Member
Try updating CUE.
Grant Bagdasarian Sat, 11/27/2010 - 20:14
You mean software update to a higher version? If so, that's not an option at this point, since I have to discuss that with my supervisor.
paolo bevilacqua Sat, 11/27/2010 - 22:45
  • Hall of Fame,
    Founding Member
Thank you for the nice rating and good luck!
