Catalyst 6500 supervisor 2/MSFC2 RAM memory
Answered Question
Nov 6th, 2010
hello everyone,
I write to ask you which command I have to enter to know how much RAM memory is installed on a Cat6000 Supervisor Engine 2 and how much is installed on a MSFC2 routing engine (separately).
I posted the "show version" and "show module" output of the catalyst.
The catalyst is running IOS 12.1.27b-E4 release software
Router#sh ver
IOS (tm) c6sup2_rp Software (c6sup2_rp-PK2O3SV-M), Version 12.1(27b)E4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Fri 29-Feb-08 13:28 by hqluong
Image text-base: 0x40008EF4, data-base: 0x4198B280
ROM: System Bootstrap, Version 12.2(17r)S1, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PK2O3SV-M), Version 12.1(27b)E4, RELEASE SOFTWARE (fc3)
Router uptime is 1 hour, 13 minutes
Time since Router switched to active is 1 hour, 12 minutes
System returned to ROM by power-on (SP by error - a Software forced crash, PC 0x402DF824)
System restarted at 09:26:13 UTC Sat Nov 6 2010
System image file is "sup-bootflash:c6sup22-pk2o3sv-mz.121-27b.E4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C6509 (R7000) processor (revision 3.0) with 458752K/65536K bytes of memory.
Processor board ID TBP06160053
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
13 Virtual Ethernet/IEEE 802.3  interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
48 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Router#   sh mod
Mod Ports Card Type                              Model              Serial No.
  1    2  Catalyst 6000 supervisor 2 (Active)    WS-X6K-SUP2-2GE    XXXX
  3   48  SFM-capable 48-port 10/100 Mbps RJ45   WS-X6548-RJ-45     XXXX
  4   16  16 port 1000mb GBIC ethernet           WS-X6416-GBIC      XXXX
  5    0  Switching Fabric Module-128 (Active)   WS-C6500-SFM       XXXX
  6    8  Intrusion Detection System             WS-SVC-IDSM-2      XXXX
  7    6  Firewall Module                        WS-SVC-FWM-1       XXXX
  8   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     XXXX
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0005.7485.9a10 to 0005.7485.9a11   3.5   7.1(1)       12.1(27b)E4  Ok
  3  0002.7ee2.3450 to 0002.7ee2.347f   4.2   6.3(1)       8.5(0.23)COS Ok
  4  0009.1240.9178 to 0009.1240.9187   2.2   5.4(2)       8.5(0.23)COS Ok
  5  0000.0000.0000 to 0000.0000.0000   1.3   6.1(3)       8.5(0.23)COS Ok
  6  0013.7fed.8580 to 0013.7fed.8587   5.0   7.2(1)       7.0(2)E4     Ok
  7  0003.e471.a4b6 to 0003.e471.a4bd   3.0   7.2(1)       2.3(3)       Ok
  8  5475.d0ac.cca0 to 5475.d0ac.ccaf   4.7   7.2(1)       8.5(0.23)COS Ok
Mod Sub-Module                  Model           Serial           Hw     Status
  1 Policy Feature Card 2       WS-F6K-PFC2     XXXX      3.2    Ok
  1 Cat6k MSFC 2 daughterboard  WS-F6K-MSFC2    XXXX      2.2    Ok
  6 IDS 2 accelerator board     WS-SVC-IDSUPG   XXXX     2.3    Ok
Mod Online Diag Status
  1 Pass
  3 Pass
  4 Pass
  5 Pass
  6 Pass
  7 Pass
  8 Pass
Router#
P.S.
The "output interpreter" tool said that the memory installed is 512 MB but i need to know how much is on the Supervisor end how much is on the Routing Engine.
Thank you very much to all!
Giorgio
Correct Answer by Matthew Blanshard about 6 years 2 months ago
Your route processor has 512mb of ram.  To find out how much the switch processor has run the command "remote command switch show version".  That will tell you how much memory is on the switch processor.
-Matt
Overall Rating: 5 (1 ratings)
lgijssel Sat, 11/06/2010 - 04:48
As per the output of sh ver, your sup2 has 64MB of RAM. The MSFC2 has a fixed amount of DRAM (256M) and this cannot be upgraded.
Two links to verify this and to provide additional info:
SUP2 upgrade procedure:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_12693.html#wp29446
MSFC2:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/hybrid/release/notes/ol_4563.html#wp259599
regards,
Leo
Giorgio Romano Sat, 11/06/2010 - 05:22
hi leo!
thank you for your answer.
but I really don't understand where you read those informations.
I suppose that this row from "sh ver" can help me but it seems to say that on the router there are 512 MB RAM.
"cisco WS-C6509 (R7000) processor (revision 3.0) with 458752K/65536K bytes of memory."
where I'm wrong?
thank you very much again!!
giorgio
lgijssel Sat, 11/06/2010 - 05:33
Yes, you are correct, the two numbers must added of course.
Sorry for that.
The links provided tell you also how much memory is on the MSFC2 and how to upgrade the sup2. (likely not required in your case)
I have been using this info in the past when I needed to upgrade a sup2 from catOS to IOS.
regards,
Leo
Correct Answer
Matthew Blanshard Sat, 11/06/2010 - 08:18
-Matt
Giorgio Romano Sun, 11/07/2010 - 00:42
hi Matt,
thank you very much for your answer.
I entered the commad you suggested and this is the output
"cisco WS-C6509 (R7000) processor (revision 3.0) with 112640K/18432K bytes of memory."
the supervisor engine has 128 MB RAM.
Thank you, thank you very much!!
Giorgio
