Catalyst 2960s Problems
Nov 7th, 2010
I wounder if there is any solution about high CPU, drops and packet loss on Cisco Catalyst 2960s yet.
We are using  4 four 2960s in a stack environment and have some problem. The CPU is high and we have port-asic drop and packet loss. When I search on Internet, there are many with same problem. This should be a big issue for Cisco to solve!
Supervisor TxQueue Drop Statistics
Queue  0: 29053
Queue  1: 0
Queue  2: 0
Queue  3: 103431
Queue  4: 0
Queue  5: 0
Queue  6: 0
Queue  7: 0
Queue  8: 579416
Queue  9: 0
Queue 10: 0
Queue 11: 0
Queue 12: 0
Queue 13: 0
Queue 14: 10478748
Queue 15: 0
8888889989899888889888888888889888888988888898888998899889888898898989
7955594760921878562798784798557757576469487928578506999769775537728153
100        *                      *                  *   **  *
90 ************************ *************** *****************************
80 #*#####*#############################################**##*############
70 #*###################################################**###############
60 #*###################################################**###############
50 ######################################################################
40 ######################################################################
30 ######################################################################
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0    5    0    5    0    5    0    5    0    5    0    5    0
CPU% per hour (last 72 hours)
              • = maximum CPU%   # = average                                    CPU%
Many thanks for any comments
Best Regards
/Magnus
andtoth Sun, 11/07/2010 - 13:47
  • Silver, 250 points or more
On Catalyst switches you should not observe high CPU utilization caused by traffic in normal cases.
In order to have a better insight on what's happening on the device, please attach the output of the following commands:
- show processes cpu
- show platform tcam utilization
- show sdm prefer
- show ip traffic
I would recommend you to check the following guide in order to help you find out the root cause and solve the problem:
Catalyst 3750 Series Switches High CPU Utilization Troubleshooting
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00807213f5.shtml
The 3750 and 2960 switches are running a similar IOS software so feel free to refer to that guide.
Andras
ciscomagu Mon, 11/08/2010 - 00:03
Thanks for your reply,
Below you have the attached files you requested.
The CPU usage is 80% before I telnet them.
It dropped to 50% when I using telnet to login. And raised to above 80% after logout.
Sometimes the CPU go up to over 90%. In this situation the packet loss appear.
I hope you can see something from the attached files.
Best Regards
/Magnus
jorge.calvo Mon, 11/08/2010 - 01:36
  • Bronze, 100 points or more
If you are using the switch at the distribution layer and it has many routes. The problem could be the sdm template you are using.
I see from your TCAM utilization output that the TCAM resources for routing are overhelmed. If you have a high traffi throughput, all the routing decissions are done in software, raising the CPU load.
Please, perform a show ip route summary and if the number of subnets is higher than 320 (your current TCAM limit), change the sdm template with the "sdm prefer routing" template.
Another helpful command to see if the problem is within the TCAM resources is "show platform ip unicast failed adjacency". If it shows any subnet, then you have to change your sdm template.
Hope this helps.
ciscomagu Tue, 11/09/2010 - 02:37
We don't use IP routing in the switch (no support), It's a very default config.
This commands you recommend me to do, they don't exist.
The software version is:
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
System restarted at 09:44:11 UTC Tue Oct 5 2010
System image file is "flash:/c2960s-universalk9-mz.122-53.SE2/c2960s-universalk9-mz.122-53.SE2.bin"
Hardware:
4 cisco WS-C2960S-48TS-L in a stack
When we telnet into the switch the CPU lower from 80% to 50%
/Magnus
andtoth Tue, 11/09/2010 - 03:05
Could you please attach an output of 'sh run' and 'sh ip route' from the switch?
ciscomagu Wed, 11/10/2010 - 00:11
We have new information about the case. Last night we had a terminal session connected to the switch  the whole time. During this time there was no packet loss, the heartbeat between teamed server cards were working great.
When we had the terminal session connected the CPU was low. (50%)
Best Regards
/Magnus
andtoth Tue, 11/16/2010 - 04:42
The fact that CPU utilization is high when not connected on telnet/console to the switch is probably caused by the following software defect: CSCth24278
High CPU when no Console/VTY activity
Catalyst 2960S switch may report elevated CPU utilization (e.g., 50%) under
normal conditions.
This will be fixed in IOS version 12.2(58)SE .
For more information, please refer to the Bug Toolkit Page on the following link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth24278
However, if your CPU utilization is 90% probably traffic is hitting the CPU. Could you please collect the output of the 'show controllers cpu-interface' command when you're observing high CPU utilization? Please capture it a few times to see which counters are increasing.
Andras
andtoth Mon, 11/08/2010 - 02:10
Looks like the problem is that you're using IP Routing on the 2960 switch but you did not change the SDM (Switch Database Manager) Template in order for the TCAM to store routes. Since there's no space allocated in the hardware for IPv4 indirect unicast routes (refer to sh platform tcam util command), the switch will forward/route packets in software, that's causing the high CPU utilization. You will need to change to LAN Base Routing template in order to allocate TCAM (hardware) space for Unicast Indirect routes.
Please check the Configuring SDM Templates on Catalyst 2960 Switches on the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swsdm.html
For more info about the SDM Templates, please check the following guide:
Understanding and Configuring Switching Database Manager on Catalyst 3750 Series Switches
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00801e7bb9.shtml
Andras
i.harvey Tue, 11/16/2010 - 04:21
Hi. I am experiencing the exact same problem
with a stack of 4 x 2960S-48FPS-L
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48FPS-L  12.2(53)SE2           C2960S-UNIVERSALK9-M
     2 52    WS-C2960S-48FPS-L  12.2(53)SE2           C2960S-UNIVERSALK9-M
     3 52    WS-C2960S-48FPS-L  12.2(53)SE2           C2960S-UNIVERSALK9-M
     4 52    WS-C2960S-48FPS-L  12.2(53)SE2           C2960S-UNIVERSALK9-M
There is no routing on this stack
CPU can go over 90%, but is generally around 50%. Packet loss happens when CPU goes over 90%.
Is the "the need change to LAN Base Routing template in order to allocate TCAM (hardware) space for Unicast Indirect routes" even if routing is no available on the switch?
Ian
andtoth Tue, 11/16/2010 - 04:33
If you are not using IP routing on the switch, there's no need to change the SDM template.
ciscomagu Tue, 11/16/2010 - 05:39
I have communicate with another Discussion thread about C2960S problem and the answer I got from there is:
“The high CPU bug is still waiting for 12.2(58).  But there's another bug CSCtg77276 which affects 12.2(53) after 6 weeks of uptime.  Although the public case notes on CSCtg77276 don't exactly mention it, my Cisco engineer informs me it could cause packet loss. Upgrading to 12.2(55) fixed our packet loss problem -- but the high CPU bug is still there”
/Magnus
andtoth Tue, 11/16/2010 - 05:58
Yes, you're right. CSCth24278 will be fixed in 12.2(58)SE, I've modified my previous post accordingly.
I think we're listing too many issues here and it's getting confusing. It would be better to handle these issues in separate threads. This thread was originally opened for high CPU utilization causing some packet drops and also high cpu when not connected to the console. The console issue is covered by CSCth24278 and if the utilization is higher than that, 'show controllers cpu-interface' output should be collected.
i.harvey Tue, 11/16/2010 - 11:41
Now running ver 12.2(55)SE - definitely less packet drops.
Many thanks
(eagerly waiting for (58) now)
regards
Ian
i.harvey Wed, 11/17/2010 - 07:37
The problem of packet loss manifested itself by affecting VOIP calls.
With packet loss being intermittent, VOIP calls would suddenly have one way traffic for a short period and then would return to normal. Now using ver 12.2(55) as opposed to 12.2(53), there have been no reports of this happening today.
The problems did not occur immediately with ver 12.2(53), only after ~ 3 weeks. the switches have been rebooted now due to the IOS upgrade, so hopefully it is not the reboot that has 'fixed' it for now
dixho Wed, 11/17/2010 - 10:26
If the problem occurs again,  I suggest that you collect the following output:
show platform port-asic stats drop
show interface count
show spanning tree vlan
Most problems like that is resolve by enable QoS and priority output queue. However, we need to make sure that the voice traffic is marked with DSCP 46 or CoS 5 by the switch or the VOIP device.
Leo Laohoo Sun, 04/10/2011 - 16:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
12.2(58)SE is now out (08 April 2011).
