PIX 501 configuration
Nov 8th, 2010
Hi - and thanks in advance for your help.
There's something I'm doing wrong with the basic configuration of this older PIX 501, and I don't know what it is...  It seems to me it should be working, and indeed it was working for a short while, and then stopped working inexplicably.
Now I can't even ping any IP outside, not even the next hop --- YET, once connected, the outside world can ping it!
And so I was hoping someone could look at the "show run" and tell me what is missing before I rip my hair out.
Here's the show run, and thanks again for your help -
(PS - the real outside IP was replaced by A.B.C.D, and the next hop by A.B.C.E)
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 7qqHBeDL51oM/AKL encrypted
passwd 8WAU9VgeZbq1ZOeK encrypted
hostname fire
domain-name xxx.pri
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
no fixup protocol sip 5060
no fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside A.B.C.D 255.255.255.252
ip address inside 192.168.6.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) A.B.C.D 192.168.6.9 netmask 255.255.255.255 0 0
conduit permit tcp host A.B.C.D eq pptp any
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 A.B.C.E 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.6.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
banner exec Private Network - Buzz off!
banner login Private Network - No Access!
Cryptochecksum:488eebb0a68315fabc877297138c0e44
: end
fire#
Average Rating: 0 (0 ratings)
binhkdinh Fri, 11/19/2010 - 15:15
First of all, you may want to use access-list instead of conduit. Quotes from a Cisco CmdRef document: "the conduit command has been superseded by the access-list command. We recommend that you migrate your configuration away from the conduit command to maintain future compatibility."
Second, is the 192.168.6.9 live?
Try these initially, then tighten the rules (ACL) when things are working:
no conduit permit tcp host A.B.C.D eq pptp any
no conduit permit icmp any any
access-list acl_inbound permit ip any any
access-list acl_outbound permit ip any any
access-group acl_inbound in interface outside
access-group acl_outbound in interface inside
icmp permit any outside
icmp permit any inside
Hope that helps.
Just modified a command.
-B
Login or Register to take actions
Posted November 8, 2010 at 8:29 AM
Stats:
Replies:3 Avg. Rating:
Views:2322 Votes:0
Shares:0
Related Content
Discussions Leaderboard
