Hi Glenn,
The default number for calls log on a IP Phone registering to CUCM is 100, once is reached this 100 the buffer is
erased. This can not be changed because it is locally saved on the phone's memory and it's a limitation of the phone itself.
HTH,
Tere.
Tere.
If you find this post helpful, please rate! :)
