CME 7.0 and Nokia E5 with SIP Client - cannot receive calls
Nov 12th, 2010
hi,
i have running a working system with CME 7.0 on a 2811 Router. IP Phones 7961,7921 both SCCP Clients, and a Nokia E65, E5 both SIP Clients.
The E65 are working without problems, but the E5 with VoiPSettings 3.x installed cannot receive calls - neither from E65 and SCCP Phones?
has someone any idea, where i can try to find the error? It seems that the VoipSettingsTool 3.x from Nokia is not working well...
thanks
Overall Rating: 5 (2 ratings)
LBS-BZ-HI Fri, 11/12/2010 - 04:14
hi,
i think the register process is ok, the only difference between the E65 and E5 is following:
E5: Contact: ;expires=3600   (Here contact is a strange value)
E65: Contact: ;expires=3600
is that normal?
thanks
Felipe Garrido Mon, 11/15/2010 - 08:25
Can you collect the following debugs for a call made to the E5?
debug voip ccapi inout
debug ccsip message
Also, can you collect the following command output.
show dial-peer voice summary
-Felipe
Felipe Garrido Mon, 11/15/2010 - 08:45
Konrad,
the debugs indicate that the E5 itself is rejecting the call.
Received:
SIP/2.0 404 Not Found
What extension does it show on the phone itself? Does it show 781 or something else?
-Felipe
LBS-BZ-HI Wed, 11/17/2010 - 02:30
it shows me following:
Username
sip:[email protected]
Domain
sip:10.95.180.5:5060; transport= UDP
Registered
i didn't found more info.
Felipe Garrido Wed, 11/17/2010 - 06:49
what client are you using on the Nokia phones that supports SIP registration? I have a E65 here in the lab that I can play with but it doesn't have the SIP client.
-Felipe
LBS-BZ-HI Wed, 11/17/2010 - 23:19
i have Nokia E65 with "SIP Voip 1.0 Settings"- they are working. but the nokia E5 installed with "SIP Voip 3.x Settings" isn't working... i think the SIP client from nokia has a bug...
Felipe Garrido Thu, 11/18/2010 - 07:02
Can you try downgrading to version 1.0 on the E5? I'll check to see if I can upgrade the E65 here in our labs.
jsalas Tue, 11/30/2010 - 15:59
Try this to change the directory number of the Nokia to the hash in the SIP req uri  header:
voice service voip
allow-connections sip to sip
sip
  bind control source-interface XXX
  bind media source-interface XXX
  registrar server
  sip-profiles 1
voice class sip-profiles 1
request INVITE sip-header SIP-Req-URI modify "sip:752@(.*) SIP/2.0" "sip:3HkqSha_SBZaN-Mrfjb4@\1 SIP/2.0"
voice register global
mode cme
source-address XXXX port 9090
no outbound-proxy
no privacy
max-dn 20
max-pool 20
authenticate realm XXXX
create profile sync 0554118347449519
voice register dn  1
number 752
name E52
voice register dn  2
number 771
name E71
To capture the hash, do a debug ccsip messages and look at the REGISTER message.
Maurizio Roggia Tue, 05/24/2011 - 04:07
I'm in the same exact  situation, voip setting 3.x give a chance just to place and cannot receive.
i'm quite sure that is something on nokia device
Maurizio Roggia Tue, 05/24/2011 - 05:13
In my case, i miss ringing sip response from E5
*May 24 12:10:28.730: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.10.1:5060;branch=z9hG4bK681F5
To: ;tag=2k9lum34hphc73eb43l8
Call-ID: [email protected]
CSeq: 101 INVITE
Content-Length: 0
while iphone for example that work also receiving the answer in ringing is:
*May 24 12:11:54.178: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 172.16.10.1:5060;received=172.16.10.1;branch=z9hG4bK69B08
To: ;tag=jurshl3rxxg30qf02oztazib9x5tsqcg
CSeq: 101 INVITE
Contact: "4005"
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Content-Length:  0
Maurizio Roggia Wed, 05/25/2011 - 05:20
I found the solution...
every nokia present the SIP INVITE changing the telephone number with an ASCII like this : ZVW-kntKmiPbSiXyX9zP
so...
it's enough create a voice class sip-profile 1
request INVITE sip-header SIP-Req-URI modify "sip:4006@(.*) SIP/2.0" "sip:ZVW-kntKmiPbSiXyX9zP@\1 SIP/2.0"
in my case 4006 is my telephone number.... with the ascii that you have to catch from the debug ccsip messages.
Hope this help.. for me.. saved the business.
Bye
Related Content
