cisco aironet 1130g
Answered Question
Nov 14th, 2010
hi
i tried to assign ip address to my access point in Lightweight  mode using command
AP(config)# interface bvi 1
but it doent continue give error "invalid input detected at  "' marker
please help..thank you
Correct Answer by Nicolas Darchis about 6 years 9 months ago
Then you cannot use lightweight access points :-)
I would suggest reconfiguring them as autonomous IOS access points.
Download the IOS software for that AP model and install it on the AP, then it will be configurable like a normal IOS device.
The command is "archive download-sw /f /o tftp:///"
If it doesn't allow  you to type that command try typing "debug lwapp console cli" or "debug capwap console cli" first but you need to be connected via console (no telnet).
Hope this helps !!!
Nicolas
Don't forget to rate answers that you find useful
Overall Rating: 4.5 (2 ratings)
Nicolas Darchis Sun, 11/14/2010 - 22:25
  • Cisco Employee,
that is because you cannot configure an access point that is lightweight. It has to be configured through the Controller.
Hope this helps,
Nicolas
Dilruwan Rathnayake Sun, 11/14/2010 - 22:33
thanks for reply,
yeah this access point is in lightweight mode  and i dont have a WLAN controller..
i cannot do any thing with this access point even cant go to the web interface.
is their any way to assin ssid or wpa security with cli ,  without going web interface.
thank you
Nicolas Darchis Sun, 11/14/2010 - 22:56
  • Cisco Employee,
as mentioned it is configured through the controller. Do you have a WLC ?
I suggest reading http://www.cisco.com/en/US/partner/products/ps6366/products_configuration_example09186a0080665cdf.shtml and http://www.cisco.com/en/US/partner/products/ps6366/products_tech_note09186a00808f8599.shtml
Nicolas
Correct Answer
Nicolas Darchis Sun, 11/14/2010 - 23:16
  • Cisco Employee,
Hope this helps !!!
Nicolas
Nicolas Darchis Mon, 11/15/2010 - 00:04
  • Cisco Employee,
I suggest you go with 12.4.21. Why do you want to go to 12.3 ?
http://www.cisco.com/cisco/software/release.html?mdfid=279537722&flowid=6775&softwareid=280805680&release=12.4.21a-JY&rellifecycle=ED&relind=AVAILABLE&reltype=latest
(this link had issues to open on google chrome for me but firefox worked like a charm).
Hope this helps,
Nicolas
