Licenses Restore in CUCM
Nov 15th, 2010
Does Licenses get backedup when you take backup of the call manager.?
I am going to replace my harddisk in the MCS 7835 which is currently running call manager 7.0(1) and going to rebuild that using bigger size hardisk. So i am planning to take backup of my CUCM and restore it after i build it in new hard disk. When doing the restore will the licenses be restored? If not what is the other way. I dont have the copy of licenses with me. Can i go and copy the license file (in the license file upload option--view file section of CUCM)in the notepad and save it with the same name and upload it after i build the CUCM in the new disk. Will the license work that way?
cnuche Mon, 11/15/2010 - 07:52
  • Cisco Employee,
When you rebuild a server you need to upload the licenses then restore the DRS backup file, so no, the lic files are not part of the backup file, you need to have those handy.
If this helps please rate.
Christian Nuche
PDI HD Team.
