How do you clear or reset memory on Aironet 1142 ?
satwindercisco
How do you clear or reset memory on Cisco Aironet 1142 Access Point ?
10 Replies 10
satwindercisco
I am asking this as two wireless access points Aironet1142n's have suddenly stopped working at the same time, I am investigating the following two errors that are occuring on them, not sure if 1 is causing the other:
1. Memory allocation of 4676 bytes failed from 0xFDE94, alignment 4
2. Interface Dot11Radio0, Deauthenticating Station 64b9.e861.71c3 Reason: Sending station has left the BSS
Have you seen this before ?? Thanks in advance
Nov 15 15:52:28.112
Information
Interface Dot11Radio1, Deauthenticating Station 0022.fac2.350c Reason: Sending station has left the BSS
Nov 15 15:52:07.955
Critical
Nov 15 15:50:29.786
Information
Interface Dot11Radio0, Station 38e7.d810.9e5d Associated KEY_MGMT[WPAv2 PSK]
Nov 15 15:36:25.335
Information
Nov 15 15:34:34.300
Information
Interface Dot11Radio0, Station 64b9.e861.71c3 Associated KEY_MGMT[WPAv2 PSK]
Nov 15 15:34:15.768
Critical
Nov 15 15:26:38.844
Critical
Nov 15 15:19:12.013
Information
Interface Dot11Radio0, Deauthenticating Station 0025.0091.446f Reason: Sending station has left the BSS
Nov 15 15:18:50.199
Information
Interface Dot11Radio0, Station 0025.0091.446f Associated KEY_MGMT[WPAv2 PSK]
Nov 15 15:15:47.409
Critical
Interface Dot11Radio1, Deauthenticating Station 0022.fac2.350c Reason: Sending station has left the BSSI
It means that client "0022.fac2.350c" has left the wireless coverage area or powered off the wireless NIC.
Client "38e7.d810.9e5d" has successfully associated/authenticated to the SSID.
What IOS are you running?
Hi leolahoo,
Here are the details, I am using as standalone:
Product/Model Number:AIR-AP1142N-E-K9
System Software Filename:c1140-k9w7-tar.124-21a.JA1
System Software Version:12.4(21a)JA1
Bootloader Version:12.4(18a)JA3
Try 12.4(21a)JY.
Did   you try rebooting the AP.
Hi Sparthip,
Yes I have rebooted and I could get a client connected, but then the error messages start appearing the logs again and no-one can connect.
The strange thing is that it has happened to two new 1142n AP's that i have bought recently at the same time ?
in the show logs output are able to see any tracebacks generated?
Surendra
Surendra BG
Hi Surendra,
Please find attached the "show memory" command when I have telnetted onto AP, also I have downloaded tech support info aswell.
Is this what you are asking about when you say  show logs output or is there another particular command ?
it will be great if you could upgrade the AP software to the latest (i guess its 12.4(21a)JY). i request you to let me know if we are facing the issue on the latest..
Let me know how this works out for you!!
Surendra
Surendra BG
Surendra BG
thanks for the response!! i will check it out in sometime..
Surendra
Surendra BG
