Forcing all traffic through Site to Site VPN tunnel
Nov 15th, 2010
I have a ASA5510 at HQ and 5505's at several remote locations. We have site to site vpn tunnels connecting all of the branch offices to HQ. Currently all of these sites come through the tunnel to access network shares and servers on our internal network, but they all go out the local ISP for general internet traffic. We would like to configure these remote sites to come through HQ to get to the internet so that they can be run through a Barracuda Web Filter to keep them from going to undesirable sites.
I have been searching for a sample configuration, but have been unsuccessful. Most of the configurations that I have done on our firewalls has been using examples of configs on existing firewalls, but we have none setup in this fashion. Here is a copy of one of my configurations that I would like to change. Any help would be greatly appreciated.
: Saved
ASA Version 8.2(2)
hostname *****
domain-name *****
enable password jWqsgNMJ79HBTl6H encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.121.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 74.172.112.58 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa822-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name bisfrucon.com
access-list VPN-Client-Splittunnel extended permit ip 192.168.121.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list VPN-Client-Splittunnel extended permit ip 192.168.121.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.121.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.121.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list OUTSIDE extended permit ip any any
access-list OUTSIDE extended permit icmp any any
access-list outside_2_cryptomap extended permit ip 192.168.121.0 255.255.255.0 192.168.102.0 255.255.255.0
access-list outside_2_cryptomap extended permit ip 192.168.121.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list outside_cryptomap_3 extended permit ip 192.168.121.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list outside_access_in extended permit icmp any any inactive
pager lines 24
logging enable
logging buffer-size 1024000
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-625.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 74.172.112.57 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
nac-policy DfltGrpPolicy-nac-framework-create nac-framework
reval-period 36000
sq-period 300
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 63.85.175.242 255.255.255.255 outside
http 192.168.121.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set peer 63.85.175.242
crypto map outside_map 2 set transform-set ESP-3DES-SHA
crypto map outside_map 2 set security-association lifetime seconds 28800
crypto map outside_map 2 set security-association lifetime kilobytes 4608000
crypto map outside_map 3 match address outside_cryptomap_3
crypto map outside_map 3 set peer 63.85.175.242
crypto map outside_map 3 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet 192.168.121.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.121.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd address 192.168.121.75-192.168.121.85 inside
dhcpd dns 192.168.100.100 205.152.37.23 interface inside
dhcpd domain bisfrucon.com interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc image disk0:/anyconnect-win-2.4.0202-k9.pkg 1
svc enable
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
vpn-tunnel-protocol IPSec l2tp-ipsec
nac-settings value DfltGrpPolicy-nac-framework-create
webvpn
svc keepalive none
svc dpd-interval client none
svc dpd-interval gateway none
svc ask enable
customization value DfltCustomization
username bfisadm password QOok3aYXW.WuMS4Q encrypted privilege 15
username ronb password lpXRxMoxgm65fI.6 encrypted privilege 15
tunnel-group 63.85.175.242 type ipsec-l2l
tunnel-group 63.85.175.242 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:2f2ff61b9ff8f3bf5345744970f4b4fe
: end
asdm location 192.168.200.0 255.255.255.0 inside
asdm location 192.168.102.0 255.255.255.0 inside
Jon Marshall Mon, 11/15/2010 - 13:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
If you want to force all traffic down the VPN tunnel then modify your crypto-map access-list to send all traffic down the tunnel ie.
to
access-list outside_2_cryptomap extended permit ip 192.168.121.0 255.255.255.0 any
and modify your nat extension access-list as well.
Jon
rebre52 Mon, 11/15/2010 - 14:01
So the following would be replaced like so?
replaced with
access-list inside_nat0_outbound extended permit ip 192.168.121.0 255.255.255.0 any
At that is all I need to do?
Jon Marshall Mon, 11/15/2010 - 14:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
replaced with
That is your NAT exemption access-list so that does need modifying but you also need to modify the access-list(s) referenced in your crypto maps. You would modify them the same as above.
Also don't forget you need to modify the access-lists at both ends of the IPSEC tunnel ie. on both devices at either end.
Edit - one other thing i forgot. At the HQ site you will need to setup hairpinning so the traffic can go in and out to the internet.
Jon
rebre52 Mon, 11/15/2010 - 14:19
Thanks so much for your help. I am going to be putting up a new location in a couple of weeks and will use this s
ite as my trial run. Once I have the commands down pat, I will start modifying existing locations.
