Warning message
OSPF auto-cost reference
Nov 16th, 2010
Hi all,
As I know, By default, if I use vlan interface to form ospf neighbor, the ospf cost should be 1 whatever what speed it is.
But now if I add auto-cost reference 10000 (default is 100). then it show all ospf interface to cost 10.Why it show this ospf cost  value?
How to count it ?
Overall Rating: 5 (1 ratings)
mtsb Tue, 11/16/2010 - 01:05
  • Bronze, 100 points or more
By default as you said if interface speed in greater that 100MBPS, OSPF metric would be a fractional value and it is not allowed so it is 1 for links higher than 100MBPS BW.
For Vlan interface, BW is 1000MBPS.
nPE1#show int vlan 1 | i BW
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
So if you see the reference BW to calculate metric to 10000, the cost is 10,000/1000 which is 10 and this is correct IMHO.
sudjacob Tue, 11/16/2010 - 07:08
the value for auto cost refrence bandwidth = cost* bandwidth/10 to the power of 6
for example I want cost 10 for 1Gbps
then my vlaue for auto cost refrence bandwidth = 10* 10 to the power 9/10to the power 6 = 10000
This is the method  used for setting cost for higher bandwidth in ospf. By default auto cost refrence bandwidth  vlaue = 100
for cost = 1
   = 1*10 to the power 9/10to the power 6  = 1000
