WLC 5508 w/ 1042s - Initial Configuration Question
Answered Question
Nov 16th, 2010
I have to do an install from scratch and was looking for some basic suggestions for the configuration. I have a 5508 that I have to tie into 6509.
I have to stand up 16 - 1042 model APs.  I'll be supporting numerous clients - barcode scanners, phones, iphones and laptops with WPA2.  I will have to build 2 WLANs - one for DATA and for a hotspot.
Does anyone have a base configuration they can share for both the WLC and the 6509 configuration?  Does anyone have a "from scratch" build process doc they could share?  Does anyone have a recommended code version ?
I've downloaded the 7.0 Configuration Guide but was hoping to get some real world guideance also.
TIA,
Amir
Correct Answer by Tiago Antunes about 6 years 5 months ago
Well, starting from the version, 7.0 is the latest so it is good to start from it.
Initial set up of 5508:
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70mint.html.
I would advise you to read carefully this section where explains the details, and best practice to configure the WLCs ports and interfaces.
Regarding config guides, I would advise you to go through the design guide:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns279/c649/ccmigration_09186a00808d9330.pdf.
And the configuration examples:
http://www.cisco.com/en/US/products/ps6366/prod_configuration_examples_list.html.
They are valid for all models of WLC.
They are the basis of the configuration and very good examples.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Overall Rating: 5 (1 ratings)
Correct Answer
Tiago Antunes Tue, 11/16/2010 - 04:05
  • Cisco Employee,
HTH,
Tiago
asafayan Tue, 11/16/2010 - 05:04
Thanks Tiago for the doc links.  I'll review them shortly.
