Click-to-call - zero for external calls
Answered Question
Nov 17th, 2010
HI,
i'm using CLICK TO CALL to dial numbers from web page.
I read numbers from a db but they haven't zero for external calls and i can't modify the db so i asky you:
Can I post to clickToDIal application a param (0) to add to number for external call?
thanks
Correct Answer by bvanturn about 6 years 6 months ago
Indeed application dial rules is what you can use. It is explained here:
http://tools.cisco.com/squish/56877
You can also disable dial rules and configure fixed values as outlined here:
http://tools.cisco.com/squish/F1DdD
Overall Rating: 5 (2 ratings)
Jonathan Schulenberg Wed, 11/17/2010 - 04:48
  • Cisco Designated VIP,
    2017 IP Telephony
Yes. Configure Application Dial Rules and CUCM will modify the number before dialing it. Also do not forget to enable the Apply Application Dial Rules on SOAP Dial Request service parameter on the WebDialer service.
