Warning message
PIX 515 Password Recovery
Nov 17th, 2010
I recently was givent he responsibility of a pair of PIX 515 which are running 6.3 software. I unfortunately needed to attempt a password recovery this morning and got an unexpected result.
During the recovery process I was prompted to see if I wanted to erase all passwords and it chose yes.
Thene the device showed me the following message:
password LKR)T)(*%&
enable password (#$($*%*%&%)$($
aaa server ssh console TACACS
aaa server local concole TACACS
Would you like to remove this configuration from the device ?
I again selected yes. I was then able to login tot he device with the default username/password. I immediately set my new password and enable password.
Once I logged out of the device and tried to log back in. It continued to be in initial mode and when i typed enable I was immediately prompted for a username and password and nothing worked.
What might I have missed ?
Kureli Sankar Wed, 11/17/2010 - 11:53
  • Cisco Employee,
Did you save the config after you changed the passwords?
-KS
apothula Wed, 11/17/2010 - 19:51
  • Bronze, 100 points or more
Hi John,
Have you changed the config register back to the old value ??
Cheers,
Nash.
John Crubaugh Thu, 11/18/2010 - 06:49
config register is on a router not a PIX. But ty for the response.
