Can LMS 3.2 manage a 3560E with the new cisco SM-ES3-24-P cards installed?
Answered Question
LMS 3.2 on Solaris 10
The 3560E was previously managed by LMS, but I just added a cisco SM-ES3-24-P card into it.
This is a 24 port switch/router module that sits inside a 3945 router.
As of now, LMS considers this a separate device (b/c I added it as a new device) but it's Unknown.
I ran inventory collection on it and the job succeeded. I'm attaching the output from this job.
So it is able to talk to it, but I'm guessing there isn't a device package out there for it yet? I just updated all of the RME device packages about two weeks ago.
Thoughts?
Correct Answer by Joe Clarke about 6 years 8 months ago
Support for this device in RME was added with Cat3560 package 7.4.  Yes, a current MDF would also be required for the proper icon to appear in the device selectors.  Make sure you download and install all available device updates for RME, Common Services, Campus Manager, and DFM and you should have full support for this switch module.
Overall Rating: 5 (1 ratings)
Joe Clarke Sun, 11/21/2010 - 12:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It's my understanding all of these switching modules are supported now.  Post the sysObjectID from this module.
Correct Answer
Joe Clarke Mon, 11/22/2010 - 23:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
