Cisco AP_1240AG stuck in rommon mode -SOLVED-
miikakirves
Hi there,
I'm facing a bit challenging problem. When I boot one accesspoint it gives only next listing in the screen:
Xmodem file system is available.
Flashfs[0]: unable to allocate available block.
The system has been interrupted, or encountered an error during initializion of the flash filesystem.
The foolowing commands will initialize the flash filesystem, and finish loading the operating system software:
flash_init
ether_init
tftp_init
boot
When I type this commands, it doesn't help at all. The output will be following:
ap: flash_init
Initializing Flash...
flashfs[0]: out of memory
...done Initializing Flash.
ap: ether_init
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ap: tftp_init
Unable to get our ip address: no "IP_ADDR" variable set
ap: boot
Loading ""...; permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
ap:
I've tried to set ip address, but flash is out of memory and even tried other measures like: Restore IOS on Cisco AP1200https://supportforums.cisco.com/thread/326515?referring_site=kapi but none seemed to work. It just doesn't take the IOS in it.
What to do?
KR, Miika
Hardware issues tend to happen suddenly :-)
8 Replies 8
Nicolas Darchis
I'm not sure there is anything else to do than returning the unit under RMA ?
Looks like a hardware condition caused this.
Nicolas
Don't forget to rate answers that you find useful
I forgot to mension that this device were in use almost a month without any other problems. But suddenly one of my co-worker gave me a call with this problem.
-Miika
That's a true. Is there any other opinions with this? Do I really have to send this device back to Cisco?
-Miika
At the ap: prompt, issue the flash_init command
Once its done Initializing Flash Issue the dir flash: command in order to view the contents of Flash, and find the config.txt configuration file.
Rename the config.txt file to config.old with the command rename flash:config.txt flash:config.old
Issue the reset command in order to reboot the AP
miikakirves
Hi everyone,
This is solved yesterday.
We used PoE switch while we tried TFTP boot. It didn't work at all. After we plugged power source and cable DIRECTLY to computer this started to work..
Sorry for bothering you all with this quite simple task.
KR, Miika
jaypanda
I have the exact same problem mentioned above.  I cannot set the IP_ADDR to do the tftp.  What is the solution?
ap: set IP_ADDR 11.11.11.9
Can't set variable -- out of memory.
This is what happens after power-on:
flash_init
ether_init
tftp_init
boot
ap: flash_init
ap: ether_init
Reset done!
ap: tftp_init
ap: boot
Error loading ""
ap:
I have exactly the same problem and I need a help !
Can you please tell me how can I solve this issue ?
Thanks in advance
