Warning message
Cisco 1131ag - I have some questions -
Nov 19th, 2010
Hello
I have a Ap which have ip 10.0.0.1 and mask 255.0.0.0
later i have configured the ip and mask using a console wired
the new ip 192.168.1.100 and mask 255.255.255.0 and gateway 255.255.255.0 and no securiy...
i have two quetsions:
1. if i have two laptops and i want to make a wlan between two laptops, i could to make the following:
     1. Cisco 1131ag act as DHCP server
     AP(config)#ip dhcp excluded-address 192.168.1.100
     AP(config)#ip dhcp pool nombcisco
     AP(dhcp-config)#network 192.168.1.0 255.255.255.0
     AP(dhcp-config)#default-router 192.168.1.100
     in each laptop configuring in the NIC "give ip automatically
thats right? or not?
2. if i hvae the followin:
destokp1 : 192.168.1.2 / 255.255.255.0
destokp2:  192.168.1.3 / 255.255.255.0
i have connected this destokp to a swithc   - - - this is lan... true?
later i will want to connect a AP using UTP wired to a port to the switch... can i do it?
in this case if the AP had 192.168.1.100 and 255.255.255.0 when i connected the UTP wired, whats happend with the AP ip and mask?
later i have two laptops and i want to make ping between destokp 1 and laptop 1
how i do it?
Surendra BG Fri, 11/19/2010 - 20:55
  • Cisco Employee,
on the switch. create the SVI.. that is interfcae Vlan X which is in the same subnet of BVI interfcae (192.168.1.X) subnet , Configure the switchport to which the AP is connected as trunk.. try to ping from Switch SVI to AP BVI.. if we are able to ping.. then connect the laptops wireless to the SSID and the laptops will grab the IP  from the internal DHCO pool which you have configured.
ANS - This is correct, make sure you have the interface VLAN in the same subnet as that os BVI on the switch and that vlan should be allowed on the port on which the AP is getting to the switch.
ANS - You need to configure a interface vlan on the swith and then assign that vlan to the port on which you are connecting the AP and destops.
>> later i have two laptops and i want to make ping between destokp 1 and laptop 1 how i do it?
ANS - I guess desktops are connected to the switch.. with the same vlan as that of AP and the wireless laptops.. if they are in the same subnet.. then its pingable.. here is the complete configuration for your requirements..
on the switch..
en
conf t
vlan 1
end
conf t
int vlan 1
ip address 192.168.1.254 255.255.255.0
no shut
end
Asuming you are connecting the AP to Fa 0/1 port on  the Switch..
en
conf t
int fa 0/1
switchport trunk encapsulation dot1Q
swithport mode trunk
switchport trunk native vlan # (# = native Vlan number)
end
Assuming you have connecting the desktops to FA 0/2 and FA 0/3 ports..
conf t
int fa 0/2
switchport mode access
switchport access vlan 1
no shut
end
conf t
int fa 0/3
no shut
end
On the AP
I assume you are able to configure normal AP configurations with SSID and Encryption...
DHCP configurations..
Its the same as the one whic you have written !!
>> If your laptops are getting the IP in the range 192.168.1.X network and if they are able to ping the int vlan 1 and the BVI interface ip.. then the pings will work between the laptop and the destop.
The above will help you!!
lemme know how this answered your questions..
Surendra
robertoxavier Fri, 11/19/2010 - 22:57
Thanks for the answer...
1. If i have a simple switch... how i do it?... this switch dont is cisco...
2. i have a problem with AP
     this AP have 3 interface : fast ethernet,radio 0 g and radio 1 a
     when i disable the radio g and enable the radio a my laptop dont see the ap...
     my laptop have installed a LINKSYS USB 600N v2
     but i disable the usb600nv2 and enable the adapter built in the laptop ,in this moment i see the ap
why have i this problem?... if the ap has enable the raido A because USB600N doesnt see the Ap but the adapter built in the laptop INTEL 5100AGN can see the ap...
Surendra BG Sat, 11/20/2010 - 01:05
  • Cisco Employee,
Hi ,
ANS - Whats the switch we are using?? we need to find how to configure it for a interface vlan... else its not possible..
ANS- May be issue with the Linksys USB issue, may be compatibility issue.. i searched the product ID but could not fine much info on this..
Lemme know how this answered your question..
Surendra
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
