For my cisco WS-C6509-V-E switches, which IOS should I download?
Answered Question
Nov 23rd, 2010
Hi All,
We have 4 cisco WS-C6509-V-E switches running in the data center. The IOS was released 2 years ago and I'd like to upgrade it. I went to Cisco website and found 2 types of IOS for cisco WS-C6509-V-E switches.  1. Cisco 6500/7600 Series Multiprocessor WAN Application Module and 2. Cisco Catalyst 6500 Series Communication Media Module. What is the difference between them? Which one should I download? The show version output shows below. Any input will be appreciated.
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 07-Nov-08 11:48 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
gw-cr-s6509ve-1 uptime is 1 year, 3 weeks, 1 day, 11 hours, 37 minutes
Uptime for this control processor is 1 year, 3 weeks, 1 day, 11 hours, 36 minutes
Time since gw-cr-s6509ve-1 switched to active is 1 year, 3 weeks, 1 day, 11 hours, 36 minutes
System returned to ROM by  power cycle at 14:29:07 EST Mon Feb 23 2009 (SP by power on)
System restarted at 22:34:04 EDT Sat Oct 31 2009
System image file is "sup-bootflash:s72033-ipservicesk9_wan-vz.122-33.SXI.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-V-E (R7000) processor (revision 1.0) with 1040384K/8192K bytes of memory.
Processor board ID FOX1215GLFK
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
4 Virtual Ethernet interfaces
86 Gigabit Ethernet interfaces
12 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Patching is not available since the system is not running from an installed image.
To install, please use the "install file" command.
Correct Answer by Jerry Ye about 6 years 7 months ago
You should not use those two download links listed in your post. Those are for special modules. What you need is the Supervisor 720 / MSFC3 IOS images. You can search this file name, and this is the latest release for SUP720
s72033-ipservices_wan-mz.122-33.SXI5.bin
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Tue, 11/23/2010 - 17:51
  • Cisco Employee,
jerry
Trending Topics: Other DC Subjects
