NV RAM problem
Nov 24th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:Standardowy; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
Unfortunately one of my 871 have a problem with configuration.
I can get to him only by AUX.
It runs only with default configuration.
When I want to copy my config to startup i received information:
NV: InvalidPointer value(1884) in privateconfiguration structure
%sys-4-nv_Block_initfall: Unable to initialize the geometry of nvram
Overall Rating: 5 (2 ratings)
Vinay Sharma Wed, 11/24/2010 - 00:57
  • Gold, 750 points or more
i found a similar Bug CSCtg46773. Please try the workaround:-
'write erase'
'copy run start'
Bug details:-
Errors:
 NV: Invalid Pointer value(6128) in private configuration structure
 %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometry of nvram
Conditions:
If the running-config and startup-config were noticed to be not the same size (dir all) and the
unit was rebooted several times during the flash boot process, the router would prompt for the
startup script and the NVRAM would be corrupted. At that point there would be no startup-config.
Workaround:
write erase is a workaround
thanks,
Vinay
_________
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
pwolsza_wolfik1 Wed, 11/24/2010 - 01:05
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standardowy; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} Unfortunately : No such site
Vinay Sharma Wed, 11/24/2010 - 01:25
i have copied the content of the bug in the previous reply. Please try the workaround.
thanks,
Vinay
