cannot login to switch
Nov 24th, 2010
I have telnet open on a switch which always worked but when I try to telnet to it now I get:
switch#192.168.1.1
Trying 192.168.1.1 ...
% Connection refused by remote host
I think the vty line is probably filled up, any idea how to clear it aside from using a console cable?
Nael Mohammad Wed, 11/24/2010 - 22:26
  • Silver, 250 points or more
Login from the console, do a "show line"  or "show user" and find the occupied connection. Use the "clear line" command to free up the connection.
clear line ?
  <0-16>       Line number
  async-queue  Clear queued rotary async lines
  console      Primary terminal line
  vty          Virtual terminal
clear line vty 0
