Make Phone Busy
Nov 26th, 2010
Hi there,
I have a Cisco phone with two DN's on CCM6.1. Just wondering if youo know how to make the "phone busy" as opposed to "line busy". In other words, if I am on a call on one of the DNs. The second DN should also appear busy to the caller.
Your help will be greatly appreciated.
Cheers for now..
Overall Rating: 3 (2 ratings)
paolo bevilacqua Fri, 11/26/2010 - 17:59
  • Hall of Fame,
    Founding Member
To my knowledge, It is not possible to do so.
paolo bevilacqua Sat, 11/27/2010 - 18:50
  • Hall of Fame,
    Founding Member
To the person that rated "1" my post above: I would love know why you did.
But I'am afraid you will prefer to hide your unfair, vindictive rating behind the privilege on anonymity, and misusing it.
Rob Huffman Fri, 11/26/2010 - 18:46
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Anuj,
Just to add to the nice note from Paolo (+5 "P")
In CUCM 7.x you can leverage DND (Do Not Distrurb) it is available in many
IP Phone states
Configuring DND Softkeys
Default softkey templates do not make a DND softkey available. To add a DND softkey, navigate to Device > Phone Settings > Softkey Template, add one to a softkey template in the Softkey Template Configuration window, and associate the template to the device.
Be aware that a DND softkey is available in the following states:
Connected
Connected Conference
Connected Transfer
Off Hook
OffHook with Feature
On Hold
Remote In Use
On Hook
Ring In
Ring Out
Digits After First
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsdnd.html#wp1073696
Cheers!
Rob
paolo bevilacqua Fri, 11/26/2010 - 18:57
  • Hall of Fame,
    Founding Member
Hi Rob, thanks for the rating, and your is is a good suggestion, but are you sure that is possible to set DnD for a non-primary DN ?
We know well that in CM is not possible, for example, to CFA a non-primary DN.
Furthermore, what DnD does in CM? OP wants a busy state.
anujnaidu Fri, 11/26/2010 - 19:19
Thanks Rob,
I have DND configured, but it does not offer busy tone to the caller on CCM's. True for CCME though. So, Paolo still gets the +5.
Allan Perocho Sat, 11/27/2010 - 06:26
hi anuj,
is this a shared line or a two lines in one phone? if 2 lines then i think you can put value 1 on your device busy trigger in your dn.
--allan--
paolo bevilacqua Sat, 11/27/2010 - 11:49
  • Hall of Fame,
    Founding Member
As OP clearly explained, what he wants is that when busy on a line, calls to the other line returns busy also.
Your suggestion does not resolve this.
paolo bevilacqua Sat, 11/27/2010 - 18:30
  • Hall of Fame,
    Founding Member
If then, why not put maximum number of calls to 1.
Sorry, but it seems you do not understand the requirement. Please read this thread again and I am sure you will.
anujnaidu Sat, 11/27/2010 - 21:01
Hi Guys,
Paolo is correct. Busy trigger only applies to the DN only. There are two separate DNs on one phone. All I want to do is if I am busy on DN1 then DN2 should should go busy to other callers. In other words one call at a time.
Thanks for trying, and your suggestions so far. much appreciated.
Gabriel Saavedra Sun, 11/28/2010 - 21:29
  • Silver, 250 points or more
Hmm try this as a workaround:
Lets say DN1 is 2000 and DN2 is 2001. Make a translation pattern that converts 2001 to 2000 and configure the busy trigger of DN1 to 1, so when callers dials 2001 and 2000 is in a call there should be the busy tone that you want. If you need to make calls through DN2 you will need to put that DN in a partition different than the one you choose for the translation pattern. Also make sure that the Calling Search Space of the people that can dial DN2 contains the partition of the translation pattern.
Gabriel
anujnaidu Sun, 11/28/2010 - 21:44
Hi Gabriel, nice try!
I want DN 2 to ring as well if phone is free. Your suggestion is great, but I think it is perhaps similar to call forwarding.
Gabriel Saavedra Sun, 11/28/2010 - 22:10
Hmm you are right, is similar to a call forward all, tell me something, do you have an IPCC in your environment?
Gabriel.
