Warning message
a problem with ACE10
Nov 29th, 2010
I installed ACE10 into Cat6500 with 12.2(33)SXI4a software. I configured svclc group with vlan 5. I created SVI for vlan 5 on the Cat6500 and I configured interface vlan 5 on the ACE. I cann't ping from Catalyst into ACE and vice versa. I'm sending you the output from some commands from Catalyst and ACE.
Router#sho module
Mod Ports Card Type                              Model              Serial No.
  3    1  Application Control Engine Module      ACE10-6500-K9      SAD1122046D
  7    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAD0911072L
Mod MAC addresses                       Hw    Fw           Sw           Status
  3  001b.2ad2.efa8 to 001b.2ad2.efaf   1.4   8.6(0.252-En 3.0(0)A1(4a) Ok
  7  0011.9201.d760 to 0011.9201.d763   4.3   8.5(2)       12.2(33)SXI4 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  7  Policy Feature Card 3       WS-F6K-PFC3B       SAD0910055J  2.0    Ok
  7  MSFC3 Daughterboard         WS-SUP720          SAD0910085E  2.3    Ok
Mod  Online Diag Status
  3  Pass
  7  Pass
Router#show ip int brie
Vlan5                  20.0.0.3        YES manual up                    up
Router#ping 20.0.0.1
Sending 5, 100-byte ICMP Echos to 20.0.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#sho arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  20.0.0.1                0   Incomplete      ARPA
Internet  20.0.0.3                -   0014.1bdf.4140  ARPA   Vlan5
Router#sho vlan brief
VLAN Name                             Status    Ports
1    default                          active
2    SYS-SW-MNG                       active
5    RT                               active
6    VLAN0006                         active
Router#sho svclc module
Module Vlan-groups
  03   1
Router#sho svclc vlan-group
Display vlan-groups created by both ACE module and FWSM commands
Group    Created by      vlans
    1           ACE      5
switch/Admin# sho run
Generating configuration....
boot system image:c6ace-t1k9-mz.3.0.0_A1_4a.bin
access-list test1 ethertype permit any
access-list test line 8 extended permit icmp any any
access-list test line 16 extended permit ip any any
class-map type management match-any mgmt
  2 match protocol telnet any
  3 match protocol icmp any
policy-map type management first-match M
  class mgmt
    permit
access-group input test1
interface vlan 5
  ip address 20.0.0.1 255.255.255.0
  no normalization
  access-group output test
  service-policy input M
  no shutdown
ip route 0.0.0.0 0.0.0.0 20.0.0.3
switch/Admin# sho arp
Context Admin
IP ADDRESS      MAC-ADDRESS        Interface  Type      Encap  NextArp(s) Status
20.0.0.1        00.1b.2a.d2.ef.a9  vlan5     INTERFACE  LOCAL     _         up
20.0.0.3        00.14.1b.df.41.40  vlan5     GATEWAY    2      219 sec      up
Total arp entries 2
switch/Admin# sho ip route
Routing Table for Context Admin (RouteId 0)
   Codes: H - host,   I - interface
          S - static,      N - nat
          A - need arp resolve,      E - ecmp
Destination         Gateway          Interface         Flags
0.0.0.0             20.0.0.3         vlan5             S
20.0.0.0/24         0.0.0.0          vlan5             IA
Total route entries = 2
So it seems like the hw problem. So is it true?
Thank you.
Best Regards
Roman
yushimaz Mon, 11/29/2010 - 19:08
  • Cisco Employee,
From above output, it seems Cat6k cannot get arp response from ACE.
This means Cat6k cannot receive arp packets or ACE cannot send.
To find out the root cause, I need capture trace between Cat6k and ACE.
Can you get capture trace on Te3/1?
When you enable 'debug arp' on Cat6k and 'debug arpmgr packets' on ACE
and then issue 'clear arp', can you see the following output? (Note: If you
configure other interfaces on cat6k, debug command makes an impact on
your system.)
## clear arp on ACE
# on ACE
switch/Admin# cle arp
switch/Admin# 2010 Nov 30 00:00:10.062532 arp/icmp mgr: (ctx:0)ARPDBG:Sent Arp REQUEST Dest 20.0.0.3 mac 00.00.00.00.00.00 Src 20.0.0.1 mac 00.07.0e.0f.2c.a1 on vlan 5  on interface id 2
2010 Nov 30 00:00:10.063521 arp/icmp mgr: (ctx:0)ARPDBG: Recd Arp RESPONSE Dest 20.0.0.1 mac 00.07.0e.0f.2c.a1 Src 20.0.0.3 mac 00.16.9c.6d.e5.80 on vlan 5  on interface 2
# on sup720
*Nov 30 00:00:10.075: IP ARP: rcvd req src 20.0.0.1 0007.0e0f.2ca1, dst 20.0.0.3 Vlan5
*Nov 30 00:00:10.075: IP ARP: sent rep src 20.0.0.3 0016.9c6d.e580,
                 dst 20.0.0.1 0007.0e0f.2ca1 Vlan5
## clear arp on sup720
# on ACE
switch/Admin# 2010 Nov 30 00:00:17.655721 arp/icmp mgr: (ctx:0)ARPDBG: Recd Arp REQUEST Dest 20.0.0.1 mac 00.07.0e.0f.2c.a1 Src 20.0.0.3 mac 00.16.9c.6d.e5.80 on vlan 5  on interface 2
2010 Nov 30 00:00:17.656595 arp/icmp mgr: (ctx:0)ARPDBG:Sent Arp RESPONSE Dest 20.0.0.3 mac 00.16.9c.6d.e5.80 Src 20.0.0.1 mac 00.07.0e.0f.2c.a1 on vlan 5  on interface id 2
2010 Nov 30 00:00:17.656719 arp/icmp mgr: (ctx:0)ARPDBG: Recd Arp RESPONSE Dest 20.0.0.3 mac ff.ff.ff.ff.ff.ff Src 20.0.0.3 mac 00.16.9c.6d.e5.80 on vlan 5  on interface 2
# on sup720
sup720#cle arp
*Nov 30 00:00:17.667: IP ARP: sent req src 20.0.0.3 0016.9c6d.e580,
*Nov 30 00:00:17.667: IP ARP: refresh static entry 127.0.0.51 with tableid 0 on idb EOBC0/0
*Nov 30 00:00:17.667: IP ARP: sent req src 127.0.0.51 0000.1500.0000,
                 dst 127.0.0.21 0000.1200.0000 EOBC0/0
*Nov 30 00:00:17.671: IP ARP: sent rep src 127.0.0.51 0000.1500.0000,
                 dst 127.0.0.51 ffff.ffff.ffff EOBC0/0
*Nov 30 00:00:17.671: IP ARP: sent rep src 20.0.0.3 0016.9c6d.e580,
                 dst 20.0.0.3 ffff.ffff.ffff Vlan5
*Nov 30 00:00:17.671: IP ARP: rcvd rep src 127.0.0.21 0000.1200.0000, dst 127.0.0.51 EOBC0/0
*Nov 30 00:00:17.671: IP ARP: rcvd rep src 20.0.0.1 0007.0e0f.2ca1, dst 20.0.0.3 Vlan5
I confirmed the behavior with 12.2(18)SXF16/A2(3.2a). I use your configuration on ACE.
(I use different version both switch and ACE since I currently use them for another
troubleshooting. If they becomes free, I'll try to reproduce with your version.)
I'm not sure ACE is wrong but I would suggest to upgrade ACE since A1(4a) is very old.
Yuji
ROMAN TOMASEK Fri, 12/03/2010 - 04:16
Hello Yuji,
I tried your method and the result is in the attachment. It seems that ACE sent ARP request, but there is no response from Sup (on the Sup this arp request is not seen). When I cleared the arp table on the SUP - the request was seen on the SUP and the ACE and the ACE sent response to the Sup.
It seems that the problem is with communication from ACE into SUP. The reverse communication seems without problem.
I would like to upgrade ACE module into higher version, but there is no way for this upgrade (because the communication between ACE and SUP is broken):-( Is there some other way how this upgrade can be provided?
Thank you.
Roman
ROMAN TOMASEK Mon, 01/10/2011 - 02:23
I'm sorry for my late answer. It is the standalone switch (no VSS). I'm sending you the requested outputs. I tired to use ACE sw A2(3.2), but the result is same:-( See:
switch/Admin# sho ver
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  loader:    Version 12.2[120]
  system:    Version A2(3.2) [build 3.0(0)A2(3.2)]
  system image file: [SUP] disk0:c6ace-t1k9-mz.A2_3_2.bin
  installed license: no feature license is installed
Hardware
  Cisco ACE (slot: 8)
  cpu info:
    number of cpu(s): 2
    cpu type: SiByte
    cpu: 0, model: SiByte SB1 V0.2, speed: 700 MHz
    cpu: 1, model: SiByte SB1 V0.2, speed: 700 MHz
  memory info:
    total: 826136 kB, free: 262548 kB
    shared: 0 kB, buffers: 1356 kB, cached 0 kB
  cf info:
    filesystem: /dev/cf
    total: 1014624 kB, used: 360736 kB, available: 653888 kB
last boot reason:  reload command by admin
configuration register:  0x1
switch kernel uptime is 0 days 0 hour 21 minute(s) 10 second(s)
switch/Admin# ping 20.0.0.2
Pinging 20.0.0.2 with timeout = 2, count = 5, size = 100 ....
No response received from 20.0.0.2 within last 2 sec
5 packet sent, 0 responses received, 100% packet loss
switch/Admin# sho vlan
Vlans configured on SUP for this module
vlan5
switch/Admin# sho int vlan 5
vlan5 is up, VLAN got assigned from the supervisor
  Hardware type is VLAN
  MAC address is 00:1b:2a:d2:ef:a9
  Mode : routed
  IP address is 20.0.0.1 netmask is 255.255.255.0
  FT status is non-redundant
  Description:not set
  MTU: 1500 bytes
  Last cleared: never
  Last Changed: Sat Jan  1 00:39:24 2000
  No of transitions: 1
  Alias IP address not set
  Peer IP address not set
  Assigned from the Supervisor, up on Supervisor
     0 unicast packets input, 39162 bytes
     552 multicast, 25 broadcast
     0 input errors, 0 unknown, 0 ignored, 0 unicast RPF drops
     77 unicast packets output, 11228 bytes
     0 multicast, 52 broadcast
     0 output errors, 0 ignored
switch/Admin# sho ip int brie
Interface       IP-Address      Status                  Protocol
vlan5           20.0.0.1        up                      up
vlan6           unassigned      down                    down
Best Regards
Roman
CZ SmartNet OMG team Wed, 01/12/2011 - 04:47
I tried your recommendation, but the behaviour is same:-( I cann't ping between ACE and Cat6500.
See:
Router#sho ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
Vlan1                      unassigned      YES unset  administratively down down
Vlan5                      20.0.0.2        YES manual up                    up
GigabitEthernet5/1         unassigned      YES unset  administratively down down
GigabitEthernet5/2         unassigned      YES unset  administratively down down
Router#sho run | inc svcl
svclc module 8 vlan-group 1
svclc vlan-group 1  5
Router#
Router#sho arp
Internet  20.0.0.2                -   001a.3097.fa40  ARPA   Vlan5
vlan5
switch/Admin# sho run interface
interface vlan 5
  no normalization
  no shutdown
interface vlan 6
  ip address 10.0.0.2 255.0.0.0
  no shutdown
vlan6           10.0.0.2        down                    down
  Mode : routed
  Description:not set
  MTU: 1500 bytes
  Last cleared: never
  Last Changed: Sat Jan  1 00:22:51 2000
  No of transitions: 3
  Previous State: Sat Jan  1 00:22:33 2000, VLAN not assigned from the superviso
r
  Previous State: Sat Jan  1 00:16:37 2000, administratively up
     0 unicast packets input, 19325 bytes
     268 multicast, 17 broadcast
     20 unicast packets output, 3354 bytes
     0 multicast, 26 broadcast
switch/Admin#
Context Admin
20.0.0.2        00.1a.30.97.fa.40  vlan5     LEARNED    3      14129 sec    up
20.0.0.3        00.00.00.00.00.00  vlan5     GATEWAY    -       * 2 req     dn
Software
Hardware
  Cisco ACE (slot: 8)
  cpu info:
    number of cpu(s): 2
    cpu type: SiByte
  memory info:
    total: 826136 kB, free: 262856 kB
    shared: 0 kB, buffers: 1360 kB, cached 0 kB
  cf info:
    filesystem: /dev/cf
switch kernel uptime is 0 days 0 hour 16 minute(s) 48 second(s)
Thank you
Roman
Related Content
