Warning message
2960s multiple match statements in class map
Nov 29th, 2010
I have some new WS-C2960S-48FPS-L with 12.2(53)SE2
When I try to add multiple match statements in a class map and apply the service policy to an interface, it come back with
QoS: class(NETMAN) Unsupported classification [GigabitEthernet1/0/47]
NETMAN is the class map name
It works if I limit the match statements to only 1 match statement in the class map
Mahesh Gohil Mon, 11/29/2010 - 23:59
  • Silver, 250 points or more
I was going through document for 12.2(55)SE and following statement found
Only one ACL per class map and only one match class-map configuration command per class map are supported. The ACL can have multiple ACEs, which match fields against the contents of the packet.
Can you match one statement in class-map and match that class-map in another class-map
like
class-map A
match acl 101
class-map B
match class-map A
match acl 102
You can try as a workaround If it works
Mahesh
