12-03-2010 04:48 AM
I have successfully configured ASA5505 7.2.(4) for split-tunnelling.
1) All my 64bit Windows7 / Vitsa systems running cisco vpn client 5.0.07.0290 (64bit) have no issues accessing LAN or browsing Internet. - Good expected rsults
2) My 32bit clients running XP / Vista running cisco VPN client 5.0.07.0410 (32bit) can access the LAN segment but CANNOT Browse the Internet.
Obviously the ASA is configured correctly so there must be an issue the the 32bit client 5.0.07.0410 (32bit) ? Should I try downgrading to the 32bit 5.0.07.0290 clients for my 32b OS systems?
Vito DiPinto
12-03-2010 04:56 AM
Hey Vito,
There are no know issues for 5.0.07.0410. Let me run some tests in the lab and see if I can see this kind of behavior.
Atri.
12-03-2010 04:57 AM
In the meanwhile, please do try downgrading and let me know the results.
12-03-2010 05:34 AM
Arti,
I have confirmed that even downgrading my Cisco VPN Client to 32bit -5.0.07.0290 produces the same results. I can access the remote LAN but not my local lan or the Internet.
At the same time I retested my Windows Vista / Windows 7 64bit OS systems with the Cisco VPN Client 64bit -5.0.07.0290 and I am able to access the remote LAN, as well as access my local lan and Internet.
Your help in resolving is greatly appreciated!
12-03-2010 06:50 AM
Atri,
Could this be a metric route issue on the workstations?
Please see attached Netstat routing info for each workstations.... there seems to be a difference with the the 2 XP systems not split tunelling vs the Windows 7 routing metrics which is working. Could this be a metric issue?
Vito DiPinto
12-03-2010 08:08 AM
Hey Vito,
I might has missed this, but what is the ip address assigned to your VPN adapter and what is the actual IP address assigned to the NIC on the XP 32 bit clients? The lab setup will take a little longer for me to test as .
Atri.
12-03-2010 06:55 AM
Vito,
What Network on the LAN are you trying to access and you are not able to?
The VPN client on Windows Vista and 7 should be a software of 64 bit version , and you have installed correctly. However, If the VPN client doesnt work, you wont be able to access even a remote VPN. So I dont think its a VPN client issue.
Could you please post your Easy VPN configuration on the ASA here ?
Mohamed
12-03-2010 07:04 AM
Mohammed,
As I indicated in the intial post here is my issue:
1) All my 64bit Windows7 / Vitsa systems running cisco vpn client 5.0.07.0290 (64bit) have no issues accessing LAN or browsing Internet. - Good expected rsults. - All is working correctly! I can access the Remote Lan behind the ASA and I can access the internet
2) My 32bit clients running XP / Vista running cisco VPN client 5.0.07.0410 (32bit) can access the Remote LAN segment but CANNOT Browse the Internet.
- I can access the Lan behind the remote LAN behind the ASA but CANNOT access the internet
Please see my observations above. .... There is obviously issues with the Client (32bit).
I am using the Cisco VPN Client cisco VPN client 5.0.07.0410 (32bit) and tried downgrading to 5.0.07.0290 (32bit) on the XP 32bit OS systems.
Vito DiPinto
12-03-2010 07:28 AM
Could you check up on the route table on the PC when you connect with the 64 and 32 bit? Also can you make sure the split tunneling policy is pushed fine by checking the route details on the vpn client?
12-03-2010 07:31 AM
12-03-2010 07:46 AM
Could be a metric issue. But then, can you run a wireshark capture on the vpn adapter interface when connected via vpn to see if an internet packet is being routed through that interface rather than the actual physical interface?
12-03-2010 08:17 AM
Looks like it is a METRIC issue as I sugessted.
I changed the metrics as with the VPN connected and I was able to access the remote LAN behind the ASA, the Internet and my local LAN. So there is obviously a "METRICS" issue with the VPN Client? Is this a known bug or issue and is there a permanent work around?. Why does the client not adjust the metrics correctly?
these are the commands I entered after the VPN was connected:
>route change 99.238.6.172 mask 255.255.255.255 172.17.69.99 metric 15 - VPN remote peer
>route change 0.0.0.0 mask 0.0.0.0 192.16 8.8.213 metric 15 - VPN remote network
route add 0.0.0.0 mask 0.0.0.0 172.17.69.99 metric 1 - local Network defauly GW
I cannot be chaning these netrics on the fly as the IP's on the remote VPN are dynamicly assigned when you connect to the VPN?
What is the permenat fix?
12-03-2010 09:46 AM
Hey Vito,
I should be able to confirm if this is a problem with 32bit clients by tomorrow. There are some known problems with metrics for routes on Windows machines(usually Vista):http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk52566
But in your case I think the problem is a little different. I would suggest you open a TAC case so that this behavior can be properly studied.
Atri.
12-03-2010 09:54 AM
Atri,
Thanks I look forward to your response. It looks like the local Default gayeway, VPN peer and VPN Network get the same Metric 1. You are able to reach the remote Lan but no access to the Internet.
Your investigation is appreciated. I will open a TAC case as well.
Thanks!
12-03-2010 05:18 PM
RESOLVED
Opened ticket with TAC - Issue seems to now be resolved. - THANK YOU!
Cisco engineer had me replace the following commands in my config to rectifty the issue with having 2 default gateways specifically impacting 32bit operating systems XP / VISTA / Windows 7.
Router config had the following acess list: access-list RA_splitTunnelAcl standard permit any
This was changed to:
access-list RA_splitTunnelAcl standard permit 192.168.8.0 255.255.255.0 - which specifically reflected the inside network of the ASA5505.
Once this was changed the default gateway's on the workstation now had proper routing.with one default gateway and now could access both the internal network of the ASA5505 and the Internet (splt-tunnel).
Vito DiPinto
