pppoe client and IOS 15
Boris Sharapov
The pppoe on IOS (15 version) does not work (when using 12.4 version- everything is OK)
I have tried it with c880data-universalk9-mz.151-1.T.bin, c880data-universalk9-mz.150-1.M3.bin, c880data-universalk9-mz.150-1.M2.bin - DOES NOT WORK.
But it DOES WORK with c880data-universalk9-mz.124-24.T4.bin.
The configuration
interface FastEthernet4
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1 service-name "xxx"
interface Dialer0
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxx
ppp chap password 7 xxx
dialer-list 1 protocol ip permit
The errors are
PPPoE: Failed to add PPPoE switching subblock
PPPoE: Unexpected Event!. PPPoE switching Subblockdestroy called
4 Accepted Solutions
paolo bevilacqua
"normal" IOS bugs.
Use what works, or complain to the TAC.
xabrouck
I didn't face any issue in 15.0M with this PPPoE client configuration:
vpdn enable
bba-group pppoe global
interface Ethernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Ethernet1/0
no ip address
pppoe enable group global
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname user@surf.org
ppp chap password 0 cisco
ppp ipcp route default
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit any
Could you try a similar configuration?
thanks,
Xavier
To the person that rated my post above as "1".
You are a very un-educated person. You come here with the expectation that people has to promptly give a complete solution for your problems, and do not accept a 100% true and correct reply.
If that is not true come forward and voice the the reason why you did low rate my posts.
I don't think that you will.
vpdn enable
Please note that despite whatever documentation saying otherwise, the commands above are NOT needed for PPPoE client, but only for PPPoE server.
I have hundreds of installations running fine without these commands. Admittedly, none use 15.0 yet.
12 Replies 12
paolo bevilacqua
"normal" IOS bugs.
That was not me
Very good, thanks for clarifying, and the nice rating given!
p.bevilacqua wrote:
"normal" IOS bugs.
Unfortunatelly, I can not complain to TAC, because I have no Cisco Service Agreement.
xabrouck
vpdn enable
ip nat inside
no ip address
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
thanks,
Xavier
vpdn enable
thanks,
Xavier
No, unfortunatelly this config wont help me. It  really looks like IOS bugs, if there is no any specific commands for IOS 15.0.
Thanks.
Vladimir,
I am from Cisco TAC and support this technology.
There was a bug opened for this not too long ago.
CSCtg38732    887 adsl Fails to get a Stable Condition
However, this issue was not seen in the latest IOS:  15.1-2T2. Please upgrade to this or a leter ios and suggest if this issue goes away. Also make sure that you are on the latest firmware as well.
Shelley.
shbhalla wrote:
Vladimir,
Shelley.
I have upgraded to the version 151-3.T The problem is solved - pppoe client works.
Thank you for your help.
facing same problem in
C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M2,
This worked for us. We modified the username and password for our solution.
Thanks!!!
