Backing up of IOS on a WLC 5508
Answered Question
Dec 6th, 2010
Hope someone can help me, I have a Cisco 5508 WLC and wanted to back up the IOS.
Is there any easy way of doing this ? or have Cisco restrict this function with the new IOS licensing model?
Second question, with WLC 5508 IOS version 7.0.98 I see there is no Field Recovery Image, is this correct ?
Cheers,
Ron
Correct Answer by Serge Yasmine about 6 years 5 months ago
Hello Didik, that is not possible, please refer to my post above.
Thx
Serge
I assume you Q#1 has been addressed above.
For your Q#2 "Second question, with WLC 5508 IOS version 7.0.98 I see there is no Field Recovery Image, is this correct ?"
Yes that is correct
(w-5508-1) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.98.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... N/A
And that is a bug CSCth43373
5508 running 7.0 shows Field recovery images version as N/a
Symptom:
5508 shows Field Recovery Image version as N/A.
Conditions:
Upgrade 5508 to version 7.0.98.0
Workaround:
None
You will need to wait for new 7.0 code to be out on Cisco.com
Please do not forget to mark the thread as resolved if you feel your question has been addressed.
Serge
Overall Rating: 5 (5 ratings)
nmajeed Mon, 12/06/2010 - 12:58
  • Cisco Employee,
Hi Ron
I'm not sure what you mean by backup of IOS on WLC 5508. You can backup the configuration of the WLC 5508 by using the WLC GUI-->Commands-->Upload-->Configuration and upload the configuration to tftp server. Another way to backup the configuration is to use the CLI of the WLC and issue the command show run-config from the WLC and save it in a test file so you have a backup of the configuration.
I'm not sure about the Field Recovery Image but the boot loader image of the 7.0.98.0 is the same as the 6.0.x software version.
Best Regards
Nasir Majeed.
Leo Laohoo Mon, 12/06/2010 - 14:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Field recovery?
Can you explain what you are trying to achieve?
Correct Answer
Serge Yasmine Tue, 12/07/2010 - 04:53
  • Cisco Employee,
Yes that is correct
Symptom:
Conditions:
Workaround:
None
Serge
ron_fourie Tue, 12/07/2010 - 11:40
Hi Serge,
Thank you for answering Q2, but Q1 is not answered yet, I know I can back up the configuration of the controller.
I would like to back up the IOS ver 6.0.196.0 that is currently running incase I need to role back.
Cheers,
Ron
Serge Yasmine Tue, 12/07/2010 - 12:36
  • Cisco Employee,
Hey Ron, for q1, when you update code on wlc the old is automatically stored in secondary boot space and new code goes to primary boot.
Make a "show boot" on wlc cli.
Anter upgrade od code if u would like to roll back u can do
"config boot secondary" save conf and reboot the wlc
Thank you,
Serge
sent from mobile
Correct Answer
Serge Yasmine Thu, 12/09/2010 - 02:25
  • Cisco Employee,
Thx
Serge
ron_fourie Thu, 12/09/2010 - 12:58
Hi Serge,
Thank you for your assistance, it has been helpful and provide the answer that I was looking for.
Ron
Serge Yasmine Thu, 12/09/2010 - 15:05
  • Cisco Employee,
With pleasurw. Take care.
Thank you,
Serge
sent from mobile
Leo Laohoo Thu, 12/09/2010 - 18:21
  • Hall of Fame,
    2017 LAN, Wireless
You "can't" backup the WLC firmware other than the same version you downloaded from Cisco Software Download website.
hi , again question....
i've upgraded one of my WLC 4400 to ios 7.x, but the rest still 6.x , this just for testing whether its working or no.
then, what i am worried happen, its not sync with wcs. try to sync, by audit. still not working.one friend said , i need to upgrade wcs to 7.x version also to make wlc and wcs sync and working.
please help if there 's correct way doing it ? since in the wcs already buildig and floor map, another worry i will lost all those things when i upgraded.
thanks alot!!!
Surendra BG Mon, 12/20/2010 - 04:05
  • Cisco Employee,
yes.. the WCS should always be in the hogher version compaared to the WLC or in the same main release.. so,
if your WLC is in 7.0 then the WCS should be in 7.0 software.. regarding the configuration that it has, you can take the back up and after upgrading you can restore the same..
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
