12-08-2010 10:13 AM - edited 03-21-2019 03:23 AM
I have a SPA2102 which has been working reliably on Ethernet. I relocated it to a location without an Ethernet jack so I had to use a WBP54G wireless-G bridge. The phone adapter still works so the configuration of the wirless-G bridge must be fine. However, every day or so, phone 1 and phone 2 LEDs on the phone adapter would go off and then I can't make or receive calls any more. To fix it, I have to unplug the wireless-G bridge's A/C adapter which in turn cycles the power to the phone adapter. Then it works fine for a day or two until the next outage.
Any idea of a permanent fix (other than keep unplugging the A/C adapter)? I appreciate any and all suggestions.
George
12-15-2010 11:45 AM
When you unplug the power of your wireless adaptor the ethernet connection of the SPA goes down. Normally this causes the reboot of the SPA and so a fresh registration to your sip server or ITSP. Try to reduce the registration period:
Use 300 or 120 seconds.
Best regards.
12-15-2010 04:40 PM
One other clue...when my SPA2102 is in this downed state, the LED status is as follows:
Power: blinking green
Internet: steady green
Phone 1: off
Phone 2: off
Thanks.
George
12-18-2010 09:21 PM
Here’s an update. I decided to solve my problem with a low tech solution: using a splitter that splits a single RJ45 wall outlet into an Ethernet jack and a 2-line analog phone jack. This is possible because the wiring in the wall is CAT5 (8 conductors). Previously, my 4-line phone gets 2 landlines from the wall outlet and 2 VoIP lines from the SPA-2102 which in turn gets its network connection from the wireless-G bridge. Now I don’t need to mess with wireless anymore as the SPA-2102 is plugged into the wall. Problem solved.
George
