Username Password
thomasandy32
I have created a username and password with command username cisco privi 15 pass cisco. when i telnet to switch it ask me for enable secret password??????  though  i have specified a privi level 15 to a user.Switch is authenticating with ACS and i have specified a privi 15 to a specific user on ACS.
The IOS is  c2960-lanbasek9-mz.122-55.SE.
14 Replies 14
Anton Noskov
Hi, i think you must  issue this command
line vty 0 4
login local
Device will take local  databace for authentication
User are authenticating through aaa they are no authenticating through local database,
aaa authentication login default local
show us your aaa config:  sh run | i aaa and sh run | i user as well as sh run | be line
Regards.
The above command will use local database for authentication  but i want to authenticate through ACS,
aaa authentication login default group tacacs+ line enable
tacacs-server host key
tacacs-server directed-request
Hello
SW1#sh run | i user
username cisco privilege 15 password 7 0526292704
aaa new-model
aaa authentication login rus group tacacs+ local
aaa authentication login console none
aaa session-id common
SW1#sh run | b line
line con 0
login authentication console
line vty 0 4
exec-timeout 30 0
password 7 04581E51577741
login authentication rus
line vty 5 15
exec-timeout 30 0
Can you add on vty line privilege level 15 command and then telnet again with debug aaa authentication .
Just to be sure it gets to tacacs+ and never hit local so the problem then lies on ACS.
Regards.
I have applied the command and it is going directly to privilege mode, The telnet request is hitting to ACS.
But i did'nt understood, ur below words,
Just to be sure it gets to tacacs+ and never hit local so the problem then lies on ACS ??????
Can u explain me what was the problem?????
Can you now confirm the user in ACS is privilege 15?
The command privilege level 15 on line vty normally will let any user telnetting whichever his privilege is directly in privileged mode without
having to configure an enable password.
But I've had the same problem once on a 1841 router where without putting this command it wouldn't work even with a local privilege 15 user.
Regards.
Alain
Attached is the Privilege 15 Access on ACS 5.0,
Seems like you are using ACS appliance, I only used windows server ACS but I guess it is ok.
Now if you don't mind users with less priv being put directly into enable mode when telnetting then you can leave the command I told you  or just put a password for privileged mode.
If the vty lines are configured with privilege level 15 then anyone getting remote access will go directly to privilege mode. If the original poster is happy with that then it works. But I think that is not what he wanted. I believe that if he will configure aaa authorization exec group tacacs+ that it will put only the specified user into privilege mode.
Rick
Rick
Hi Richard,
I asked him to do so to test and told him that now all users would get into privilege 15.
But I gave him a link to a thread in this forum in security-aaa where the aaa authorization is talked about and he said it didn't help him.
I tried with a local database and giving a user privilege 15 is enough to let him go into enable mode directly after login.
But on a 1841 I had same problem with local database and i had to put privilege level on line but I had no users with lower privileges then.
Regards.
Alain.
