12-09-2010 11:28 AM
This is a duplicate of http://supportforums.cisco.com/thread/2056256 No one responded, so I figure it's on the wrong forum.
Cisco RV082 Dual WAN VPN RouterI recently received a Cisco RV082 Dual WAN VPN Router, and I have a less than optimal connection speed through my ISP. It's fastest they have for DSL, no cable companies around. I could potentially double the speed of my internet if they install an extra DSL line. Would this router handle it? Would I use both WAN ports? I'm not sure where to begin, so this forum's help is needed and much appreciated.
Thanks again.
Solved! Go to Solution.
12-09-2010 01:13 PM
I don't see why not. The device claims it can do it in either failover or load balancing mode.
Yes it will use both WAN ports with the load balancing configuration enabled.
12-09-2010 01:13 PM
12-20-2010 09:50 AM
Thank you letsgomets.
02-05-2011 08:38 AM
Did you ever get this to work, I have the RV082 and I am trying to do failover between DLS and CABLE but I cannot get the DSL to work with that router.
