Cisco 877 wireless password
Dec 12th, 2010
  • Bronze, 100 points or more
Dear All ,
I configure the below on my Cisco877 router , I can connect to wireless but no password authentication .But when i change authentication method it doesn't connect .
The below is my config. with this i can connect, but no password
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 30
encryption vlan 1 mode ciphers wep40
ssid Shekkeer
    authentication open
    guest-mode
    wpa-psk ascii 0 0125345235
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
bridge-group 1
bridge 1 protocol ieee
bridge 1 route ip
Haris P
Overall Rating: 3.1 (6 ratings)
Nicolas Darchis Sun, 12/12/2010 - 11:29
  • Cisco Employee,
replace
with
encryption vlan 1 mode ciphers tkip
WPA goes with tkip encryption, not wep.
Nicolas
Don't forget to rate answers that you find useful
Haris P Sun, 12/12/2010 - 12:05
Dear Nicholas,
I tried the command you specified ,but it is still connecting without
any password ? Any Clues
The below is my runnning config
no ip address
ssid Shekkeer
authentication open
guest-mode
wpa-psk ascii 0 0102038989
ssid Test
authentication open
wpa-psk ascii 0 cisco123
36.0 48.0 54.0
station-role root
bridge-group 1
Shekkeer(config-if-ssid)#authentication key-management wpa
Error: Encryption mode cipher is not configured
Nicolas Darchis Sun, 12/12/2010 - 22:53
  • Cisco Employee,
Yes I forgot one command actually :
To be typed under your SSID configuration.
That should definitely work then.
Nicolas
Haris P Sun, 12/12/2010 - 23:00
Dear Nicholas ,
I already tried that command
#interface Dot11Radio0
ssid Test
When I added Encription cipher ,it doesn't connect with the ssid
password ..I dont know what's happening
Nicolas Darchis Sun, 12/12/2010 - 23:12
  • Cisco Employee,
It's a small "cosmetic" problem I guess.
Because your ssid is in vlan 1 you should replace "encryption vlan 1 mode ciphers tkip" with  "encryption mode ciphers tkip"
Then it should allow you to go for "key-management wpa"
Nicolas
Surendra BG Mon, 12/13/2010 - 09:04
  • Cisco Employee,
if you configure the below command
"encryption vlan 1 mode ciphers tkip" then under the SSID you need to map the VLA Nas well.. that is..
dot11 ssid
vlan 1
auth open
So, my wild guess.. can we reconfigure the same from the scratch? by deleting the SSID and then reconfiguring..
Surendra
Surendra BG Mon, 12/13/2010 - 09:07
  • Cisco Employee,
and also make sure.. in autonomous.. its as simple as this.. ONE SSID : ONE VLAN mapping
Surendra
Haris P Mon, 12/13/2010 - 11:29
It worked with below config...Thanks everyone for your help
Im, posting the config. I hope it will help some one in future
bridge irb
no ip address
ssid TEST
    authentication open
    guest-mode
    wpa-psk ascii 0 0102058745
54.0
station-role root
bridge-group 1
interface Vlan1
no ip address
ip nat inside
ip virtual-reassembly
bridge-group 1
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 102 interface Dialer1 overload
bridge 1 route ip
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
