VPN - Dynamic IP
Dec 13th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I have Cisco 877 routers, with ethernet (LAN) and ADSL (external) interfaces. The ADSL interface gets dynamic IP.
Is Site to Site VPN  with Dynamic IP and Internet Browsing Possible on the Same Router.
Anthony
Lei Tian Mon, 12/13/2010 - 06:34
  • Cisco Employee,
Hi Anthony,
When you define the ipsec peer, it can be configured either in IP or hostname, so if you can get hostname from ddns, I think it should work too.
Lei Tian
anthony.dyne Tue, 12/14/2010 - 10:54
Can I get help with Demo config for VPN with Dynamic IP
thanks
Anthony
