Cisco ACS upgrade
Answered Question
Dec 17th, 2010
is it possible to upgrade from ACS v.3.3 directly to 5.2 ? Or do I need version 4.X in between?
Thanks for your help.
Correct Answer by Jennifer Halim about 6 years 6 months ago
Cheers, please kindly mark the post as answered if you have no further question. Thank you.
Overall Rating: 5 (1 ratings)
Jennifer Halim Fri, 12/17/2010 - 02:46
  • Cisco Employee,
You can't upgrade ACS 3.3 directly to ACS 5.2.
ACS 5.x is completely different to ACS 3.x and 4.x.
There is specific hardware that you need to run ACS version 5.x, and here is the list:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/release/notes/acs_52_rn.html#wp70853
Here is the migration guide to ACS 5.x:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/migration/guide/Migration_Book.html
Hope that helps.
m.feuerer Fri, 12/17/2010 - 02:52
Thanks for your answer.
I think my question was unclear. I know about the different hardware. We plan to install the new 5.2 in VMware.
My question is, if I can import our user datas from version 3.3 to 5.2 directly?.
Thanks.
Jennifer Halim Fri, 12/17/2010 - 03:00
  • Cisco Employee,
No, you can't migrate user data directly from 3.x to 5.x.
And it's quite a complex process to migrate from 4.x to 5.x, and here is the migration guide specifically:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/migration/guide/Migration_overview_oper.html
It's a 2 phase process and you would need 2 servers for the migration (1 migration server and 1 ACS 5.x server).
Correct Answer
Jennifer Halim Fri, 12/17/2010 - 03:30
  • Cisco Employee,
