Warning message
Incoming calls beep on current calls--like a call waiting function. Is there a way to turn this off?
Dec 17th, 2010
New UC540 install in the last two weeks.  Has current software load.  Can this be done in CCA?  Thanks, Chad
Overall Rating: 5 (1 ratings)
greenturtlesteak Sat, 12/18/2010 - 10:29
  • Bronze, 100 points or more
I don't think this can be done with CCA, but try adding huntstop channel to the ephone-dn.
Albert Wilhelm Sat, 12/18/2010 - 20:06
Hello Chad,
To disable a directory number from accepting call-waiting requests use the command no call-waiting beep accept at the ephone-dn.
Here is a an example.
UC540#conf t
UC540(config)#ephone-dn xx (where xx = the DN number)
UC540(config-ephone-dn)#no call-waiting ?
  beep  Call-waiting beep in the earphone or speakerphone
  ring  Call-waiting ring on the phone base (instead of beep in the earphone or
        speakerphone)
UC540(config-ephone-dn)#no call-waiting beep accept
Hope this helps.
Bert Wilhelm
APW Solutions
Austin, TX
