Best WAP to get for small business
Dec 17th, 2010
Hi.  I'm certainly not a network engineer by any means, but I do run a small business which has 6 employees.  Most have desktops, but some, like myself have laptops and PDAs which require wireless service.
I've burned through several cheap wireless routers in the past couple years, and it dawned on me I could use just an ordinary router and get a wireless access point to provide good coverage in the office, (hopefully much better than what I can get at best buy).
I'm relatively ignorant about most of the technical stuff which you folks converse in, but I do not plan to buy a wireless lan controller, just a good, draft N wap which will provide the best signal I can get.  I also hope to configure it myself on our existing network.  It appears that the 1260 is the latest, but it needs a WLC.
Based on my admitted ignorance on the matter, what is the best draft N enterprise class WAP I can buy for the money?  1141?  1142?
My thanks in advance.
Pete
Overall Rating: 5 (2 ratings)
Surendra BG Sat, 12/18/2010 - 22:29
  • Cisco Employee,
In short.. Go for either 1141 AP or 1142 AP.. both of them are good and powerfull
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Rob Huffman Sun, 12/19/2010 - 10:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Pete,
Just to add a note to the great tips from Surendra (+5 "S")
Just make sure to order the "stand-alone" model not the LAP controller
based model. Something like;
AIR-AP1142N-A-K9
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502797.html
Cheers!
Rob
Surendra BG Sun, 12/19/2010 - 17:07
  • Cisco Employee,
ha ha Yup i forgot to mention autonomous thanks Rob!!
Surendra
