L2TP IPsec doesn,t work on ASA 5510
Dec 22nd, 2010
Hey, im nearly to gettin crazy.
I'm trying to setup a L2TP VPN Connection on my ASA 5510 to connect with Android/Windows (Native Clients).
I'm using the newest Releases:
Cisco Adaptive Security Appliance Software Version 8.3(2)
Device Manager Version 6.3(5)
My asa config just the interesting part:
crypto ipsec transform-set trans esp-3des esp-sha-hmac
crypto ipsec transform-set trans mode transport
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dyno 10 set transform-set trans
crypto map vpn 20 ipsec-isakmp dynamic dyno
crypto map vpn interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
l2tp tunnel hello 100
group-policy sales_policy internal
group-policy sales_policy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
tunnel-group DefaultRAGroup general-attributes
address-pool client-pool
default-group-policy sales_policy
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
If i try to connect with a Windows 7 Client (NOT behind NAT) I get the Error 691.
I see that Phase 1/2 are working with debug:
Dec 22 16:32:16 [IKEv1]: Group = DefaultRAGroup, IP = XXXXXX, PHASE 1 COMPLETED
Dec 22 16:51:25 [IKEv1]: Group = DefaultRAGroup, IP = XXXXXX, PHASE 2 COMPLETED (msgid=00000001)
Then I see this "Error":
Dec 22 16:51:26 [IKEv1]: Group = DefaultRAGroup, IP = XXXXX, Session is being torn down. Reason: L2TP initiated
I don't understand why it doens't work....
I tried many templates from the net but nothings works.
can someone give me an advice?
sasagcisco Wed, 12/22/2010 - 23:22
Hey Jennifer
I tried that also before with pap authentication and also the nat-traversal. but it still get the same error:
Dec 23 08:19:25 [IKEv1]: Group = DefaultRAGroup, IP = 87.xxx, Session is being torn down. Reason: L2TP initiated
I reconfigured the whole VPN Stuff from the reference config but without the AAA and nat settings because i use local login and the IP's from the same subnet as attached to the inside interface.
tahequivoice Mon, 10/17/2011 - 18:08
Has anyone been able to resolve this? I have the exact same issue with a DroidX client.
Michael Richter Mon, 10/17/2011 - 21:43
Yeah i solved it.
The only problem was the wrong parameters for my usernames.
i have had to use nt-encryptet at the end:
username righter password xyyz nt-encrypted.
after that it works.
tahequivoice Tue, 10/18/2011 - 06:14
Thanks, I will give this a try later. Dont have access to a Droid right now to test it, but went ahead and setup the user as described.
Mouhamad Kias Wed, 01/20/2016 - 07:05
The below change worked for me.
tunnel-group DefaultRAGroup ppp-attributes
no authentication pap
authentication chap
authentication ms-chap-v1
authentication ms-chap-v2
And added the user
Username <name> password <passwd> mschap
