Cisco wireless and Apple Mac woes
Dec 23rd, 2010
Hello all,
I've been working with Cisco wireless and WLC's for a couple of years now but the recent onslaught of Apple Mac's is giving me heart burn.  I've seen this at numerous sites now and need to throw it to eht community for guidance.
Basically we have had a number of instances where the Macs just fall off the wifi.  Sometimes it's when they wake from sleep and other times when roaming between AP's (1131s with same SSID's).  Our standard install is WPA2 and per ap local authentication.  PC's work fine and never an issue.
We have completed a survey with a spectrum analyser and no RF interefence is present nor errors on the radio interface.
Questions:
- Is there a preferred Cisco config/setup for Mac's to work reliably?  I've heard loads of rumors but nothing concrete and nor can I find anything specific.
- Should I be setting up WDS in case there is an authenticating issue.
- For those who are Mac gurus and happen to be reading. What Mac options we should look at?
This has all come to a head because the clients IT company who recommended the Macs (different from us doing the network infrastructure) are insisting that the problem is Cisco incompatibility and that we should rip out the Cisco kit and install airports (what tha!!!).
Thanks in advance for any pointers.
For those who like a config here it is .... Vanilla stuff really
Building configuration...
Current configuration : 2236 bytes
version 12.4
no service pad
service password-encryption
hostname AP4
no logging console
enable secret xxxxxxxxxxxxxxxxx
no aaa new-model
dot11 syslog
dot11 ssid Home
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode
   wpa-psk ascii xxxxxxxxxxxx
dot11 ssid avnet
   vlan 2
   authentication open
   mbssid guest-mode
   wpa-psk ascii xxxxxxxxxxxxxxxx
username abcd password 1234
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
ssid Home
mbssid
speed  basic-1.0 basic-2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 192.168.10.54 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
no ip http server
no ip http secure-server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Average Rating: 4 (2 ratings)
surbg Thu, 12/23/2010 - 05:58
Yeah!! even i have come across multiple issue with MAC and Cisco.. these are the below settings which i normally do on the cisco gears and most of the times this solved the issue..
on the IOS AP disable Aironet Extentions and set the poer local and ofdm to max
no dot11 extension aironet
power local cck max
power local ofdm max
end
On the WLC, disable Aironet IE..
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
davidfield Thu, 12/23/2010 - 06:21
Thanks Surendra,  I shall set and see what feedback I get.  Did this solve the problem for you?
surbg Thu, 12/23/2010 - 06:37
Yes most of the time this resolved the issue.. You can check it out..
Surendra
Login or Register to take actions
Posted December 23, 2010 at 5:38 AM
Stats:
Replies:5 Avg. Rating:4
Views:3176 Votes:0
Shares:0
Related Content
Discussions Leaderboard
